Pipo M9 Pro - Finless 1.5 ROM
Originally posted by sidh View Post
Originally posted by Finless View PostI did not remove it. I believe it is built in the stock ROM (it was on the previous stock ROM) but I did not test it.
Is it difficult for developers to add support for cifs.ko (and tun.ko) by default in the ROM available ? (or avalaible for people who make donations )
Regards,
Originally posted by peeceecee View PostToday i wanted to charge my M9pro with 12% left.. It wouldn't charge and the charginglight keeps blinking on and off constantly. Now my M9pro has a dead battery and no charging at all, except constant boots...
Any suggestions??
You have constant boots,so the battery can't be dead,but keeps consuming power so tick the reset hole so power is OFF.If the battery is completely dead it will give problems when the issue is solved and you try booting with no charge at all
Any suggestions??
We went direct to Pipo who wouldn't cover the charger under warranty, but sold us a new one for a few dollars. In the meantime we kept jiggling the cord or she shared the charger from my M9 Pro.
Hope that helps.
Originally posted by Nordo View PostMy wife's M9 Max had problems with it's charger. But if we carefully moved the cord close to where it goes into the moulded plug (that connects to the tablet) the red light would stay on steadily. The trick was to arrange the cord so that you could let go and the charger would continue to charge.
Hope that helps.
Thx all..... I ordered a new charger, so in a few days i'm back up again..
Originally posted by PipoM9Pro View PostWe always have two per tablet.....one is always a backup....or work\travel...
Sent from my GT-I9300 using Tapatalk
Originally posted by jameswalker457 View PostHere's a question for you..... Do you know if PIPO chargers are a replica of a generic type? I'm after finding a UK plug and apparently pipo are having manufacturing problems....
I can't answer as to "generic type", but my M9Pro came with the US 120V charger and they also included a UK travel adapter that looks just like:
Mine is 10A 250V instead of 13A at the above URL, but the charger just plugs into the adapter. I have to ASSUME that the two pins and one prong are what you are looking for. Or maybe you are looking to pickup a charger in the UK that has the same 5V 2.5A DC output as whatever came with your tablet???
It took all of 2 seconds for me to realise the problems of that solution and quickly ordered a replacement from Pipo.
BTW, I think all their chargers suit US wall plugs, and everyone else has to buy an adaptor.
I've seen pictures of EU plugs and UK plugs on some web sites...so I think they are available from somewhere.
The problem with using a generic charger is that the voltage HAS TO BE the specific spec for the tablet.
I fried a Pipo tablet one time using the wrong charger. There is circuitry on the motherboard that is meant to protect the battery from over voltage, but if the circuit it tripped, you can't ever charge the tablet again...EVER.Randy
Originally posted by Cyprusgrump View PostI got a UK charger for my last tablet (window N101 II) from these guys...
Originally posted by jdv007 View PostI recently purchased a universal charger from Walmart for $18. It has multiple voltage settings, including the 9 volt that the M6 requires.
This is the M9 Pro thread and the M9 uses 5 volt DC for the input charge.
I bought a couple of these off Amazon to charge my M9 Pro.
There are currently 5644 users online. 1 members and 5643 guests.
