How is GPS or isn't the module missing here to?
Pipo M9 Pro - Finless 1.5 ROM
Can't reboot or shutdown the tablet
Hi all,
At the moment, I've never had a problem with any of the Roms (Riley or Finless).
I prefer the KitKat so I flashed my tablet with the new RileyRom.
I met a very annoying problem : impossible to stop the tablet itself. When I reboot or shutdown, the process is always active & never stops.
I've to make a hard shutdown.
I keep the original SU (the one with the Rom), then I tested the updating, then I stop caused by standard hard boutons : nothing works ...
I can re-flash th Finless 1.5 or one of the RileyRom without problem (with the good loader)... and my tablet can again reboot or stop...
Has anyone experienced the same symptoms, and do you see a solution ?
I'd to reflash 6/7 times (including loader)... and my tablet can again reboot or stop...
... Happy New Year !I cna tpye 300 wrods pre mintue !!!
Excuse me for my bad english writing (never stops after the 1st start ... it's not a bootloop).
Not a bootloop, my tablet NEVER stops when I want to reboot or shutdown.
... just never stops..... the process for the shutdown is always active.
I use the version of SU with this Rom, I update it, I try to stop with the physical stop button : nothing, NEVER !
... only that I do a reset (with a pin) ...
I re-flash the tablet with the Finless 1.5, and I don't meet the problem : I can again reboot or shutdown the system (halt, shutdown -h now, under nux & so on...)I cna tpye 300 wrods pre mintue !!!
Originally posted by poil View PostExcuse me for my bad english writing (never stops after the 1st start ... it's not a bootloop).
Open RKbatchtool ,without device attached TO pc with usb.
Push both buttons(esc and power )en hold them pushed while you now connect the usb to PC.
Now RKbatchtool should see the device and you can flash another rom now.
This is what I do for every shutdown (reset pin, RKbatchtool), with a flash between a restart ... but I'll not flash my whole life for each stop of the tablet, héhééé !
This problem is present at each stop without exception...
Sniff', I prefer the KitKat (like on my nexus), but I'll wait another rom to see if I've the same problem.
Thx you anyway !
Edit : I'm in the wrong thread, I thought in the "Pipo M9 Pro RileyROM 2.5.2 KitKat"...I cna tpye 300 wrods pre mintue !!!
Originally posted by poil View PostThis is what I do for every shutdown (reset pin, RKbatchtool), with a flash between a restart ... but I'll not flash my whole life for each stop of the tablet, héhééé !
Thx you anyway !
Is the device OFF when you put a pin in the reset hole?
Yes, I tick the loader in batchtool before start flash.
I can see that the system can't halt the shutdown process.
The first times, I thought the SU doesn't correctly took the rights (that's why I update it), but it doesn't seem that. And this is the same result when I try to stop the tablet by pressing the physical button "off" (or stop in english, I don't remember).
Now, I'm on the Finless 1.5 rom : no problem stopping in, as KitKat...I cna tpye 300 wrods pre mintue !!!
Originally posted by poil View PostYes, I tick the loader in batchtool before start flash.
I still have the problem under KitKat, and yet I flashed 5 or 6 times since this morning.
I don't have it (reboot or shutdown doesn't work at all) under finless Android 4.2.2.
I saw faysoft had the same problem in the thread "Pipo M9 Pro RileyROM 2.5.2 KitKat"I cna tpye 300 wrods pre mintue !!!
Originally posted by poil View PostI still have the problem under KitKat, and yet I flashed 5 or 6 times since this morning.
Originally posted by poil View PostYep, that's what I'll do : I was very satisfied, no freeze & bug for me, smoothy..
It's just that I prefer the launcher with KitKat, and I feel it's more "light".
I'll see it with the next Rom, if it goes...
Thx again for your answers !
I agree...the KitKat is still a little rough...but its nice to know what the problems are.
If you want to maintain full functionality just stick with this Finless ROM.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
There are currently 3299 users online. 0 members and 3299 guests.
