Pipo M9 Pro - Finless 1.5 ROM
Originally posted by Elsmurfo View PostJust flashed this room and i almost feel like its slower then the original rom?
Have the following problems:
Cant rotate screen! (rotation not locked)
Anoying problem with swiftkey and the lower bar in the rom (the bar is above the swiftkeyboard).
Anyone have some tips?
LOT's of people using my ROM and your the first to report this issue.
Originally posted by Kenneth View Posti am using kasty rom not finless
PLEASE do not ask here about Kasty ROM and problems. Please do that on his web site.
While I support talk about other ROMs made by other people here on FreakTab, WHY are you asking about Kasty ROM in my ROM thread....
Make a new post / thread and ask...
DON'T do it here in my ROM thread about someone elses ROM
Seriously... does that make sense to you to ask about problems about another ROM in my ROM post?
But personally I doubt you will get much help here. Ask Kasty on his site since it is his ROM. Oh and good luck with that.... The guy supports his ROMs about as well as China supports customers... SILENCE
BobLast edited by Finless; 29 January 2014, 03:08."Pzebacz im, bo nie wiedzą, co czynią"
Re: Pipo M9 Pro - Finless 1.5 ROM
Originally posted by Elsmurfo View PostSorry, the screen rotation problem was soolved by a restart of the tablet!
how do i fix the keyboard problem with the bottom bar?
Sent from my PiPO M9Pro using Tapatalk ProPROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Hi guys first of all sry for my english.
I have pipo m9 pro 3g and i follow step by step the the read me file all was ok.. i do erase nand succes.
and i flash rom sucess too.. but after this i wait for 2-4-5-6-10 minutes and my tablet stuck on android robot with red triangle.
after of these cant do anything i cant take tablet to recovery mode or something... only after reset starting with finless logo and after of this stuck to red triangle...
i think my mistake was the usb cable i put on usb not on host.
what can i do now please help me!
rkbatch tool dont recognize the tablet anymore!
Connect tablet to PC using the USB port...not host. With the USB cable that came with the tablet.
Open the flash tool in windows.
Hold ESC and press Power.
The tool will show your tablet in Loader mode...which is flash mode.
Erase idb.
Flash ROM again.
Sent from my M7ProRandy
Nothing happend.
if the screen pass from pipo m9 logo to red triangle, i cant do anything only reset from tablet..
I use the original cable and its plugged on usb not to host.
Yesss! the problem solved.. i reinstall the adb drivers and the tablet found on rkbatch tool.
Now i follow the steps again to install the rom.
Originally posted by baspax11 View PostAfter reinstall this rom i get the same red triangle.
i cant install it.
I'm getting angry about this stupidties,ONCE AGAIN
READ...READ....READ...READ
Batchtool is for Arcatablets ROMS
Originally posted by ludoke View PostMaybe you should use the Flashtool witch is included in de Finless package ?
i told that i use the bktool AFTER faild install to recovery NOT to install.
it would be better to stop trolling on the forum with "suggestions" and help in my problem if you can help...
btw for 3rd time the same happend so i dont try it again.. ill install the 4.4.2 that is οκ too...
Are sure you are flashing an M9 Pro? The original M9 won't boot to this ROM.
There are currently 2961 users online. 1 members and 2960 guests.
