I would recommend using the overclocked kernel generated by Noderat at this link:
Choose V3.0 for TV Sticks, and you want to use AP6210 (Fixed). I run the OC kernel and it helps a lot with smooth video play and unlocks the low performance T chip to give you an actual 1.6Ghz processing speed rather than being locked at 1.4Ghz. My MK908ii TV stick doesn't get hot at all just warm and runs great.
The issue with sound control is a bug in the Beta ROM, and I keep hoping Finless with come out with a final version of it with the fix. Your TV volume will work just fine, but the internal volume control of the system goes from off to full, this doesn't allow you to change the volume in the software at all, so just leave it at 100% and use your TV to control the volume as I do with a receiver.
For best video playback I use BXBMC by Flumpster: http://www.freaktab.com/showthread.p...BMC-(Beta-3-4)
This one is developed for our processors and runs flawlessly on my system. I even stream HD video from my home cloud drive with it and it's perfect.
Hope it all works well for you.
