Is there any solution for this problem?
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Guest
Hi bob,
I found some information saying that in your rom (Finless ROM 2.0 – KitKat 4.4.2) You have a working HLS Smoothstreaming.
Could anyone send me the following files ?
libffmpeg.so
ibhevcdec.so
libmediaplayerservice.so
librk_on2.so
and librkffplayer.so.
Can anyone confirm this rom works with NPO / Foxsport / 3FM ? Something that uses HLS streaming? Thank you!
Flashing of CX-919
I followed your extensive guide and this was the first time that I have ever Flashed a device and I have to say that your guidance was excellent. I have now got KitKat on my cx-919.The only slight issues i have with the new ROM is that the download icon on my apps list does not work and screen flickers although this does seem to have settled a bit.
Many thanks.
boot looping
so i had finless 1.4 on my mk908ii and it was working great.
went on vacation for a week, and when i came home, turned on my tv and it was stuck at the android boot screen, (boot looping).
I am trying to update to this new 4.4 KK version, and having trouble getting the computer to recognize that its plugged in (flash mode).
I cannot get to this point to change the settings since it's boot looping
"If at the bottom of the tool you see "No found RKAndroid rock usb".We need to make changes in settings to turn on USB storage
Go into settings and click on developer options. Make sure USB debugging is OFF.
Go into storage settings. At the top right are 3 dots. Click it and select MASS Storage box.
Go into USB menu and turn on USB. Note: on first boot this check box is out of sync so you may have to click it twice.
4) Now at the bottom of the PC flash tool you should see "Found RKAndroid Mass Storage Usb"."
I can get to the bootloader screen if the stick is plugged into the tv,
is it possible to update from external file using the bootloader? should i wipe/factory reset, clear cache?
I am out of options, please any assistance would be greatly appreciated!
Thank you so much
EDIT:: WHAT A NOOB.. wrong micro usb port.... .....
EDIT 2:.. getting an error message saying device can not do switch, because it is not msc device? the alternate reboot tool also fails..
EDIT 3: flash perfectly... sorry for a wasted postLast edited by ycb; 27 May 2014, 07:00.
Hi, I installed this on 2 MK809IV I got, both working flawlessly, added 19mm x 19mm copper heat sink, running 18xx O/C on CPU only (no heat sink on memory or mali) BUT....
external_sd has no access (damn G**GLE and their stupid Apple-like'ish crap)
Any way of patching this ROM to allow external_sd access back?
Thanks!
partial dmesg to see if we can get webcams working?
Code:... [ 0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for <ion> [ 0.000000] memory reserve: Memory(base:0x97000000 size:24M) reserved for <fb0 buf> [ 0.000000] memory reserve: Memory(base:0x96800000 size:8M) reserved for <camera_ipp_mem> [ 0.000000] memory reserve: Total reserved 152M [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] bootconsole [earlycon0] enabled ... [ 0.783153] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 8000 [ 0.784292] rk3188 cpufreq version 2.2, suspend freq 816 MHz [ 0.784605] rk_cam_io(1761):new_camera[0] have been configed as attach flash, but CONFIG_SENSOR_FLASH_IOCTL_USR isn't turn on! [ 0.784762] rk_cam_io(1761):new_camera[1] have been configed as attach flash, but CONFIG_SENSOR_FLASH_IOCTL_USR isn't turn on! [ 0.784964] VPU_SERVICE: failed on clk_get pd_video [ 0.785022] VPU_SERVICE: failed on clk_get aclk_ddr_vepu [ 0.785067] VPU_SERVICE: failed on clk_get hclk_cpu_vcodec [ 0.785109] vpu: power on [ 0.785169] VPU_SERVICE: checking hw id 4831 [ 0.785613] vpu: power off...done [ 0.785661] VPU_SERVICE: init success ... [ 1.835855] ddrfreq: fix cpu pause bug [ 1.835900] ddrfreq: normal 300MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz [ 1.837974] rk_cam_cif(3274):rk3066b-camera version: v0.3.18 Zoom by ipp======================================================= [ 1.838707] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.838755] ======================================================= [ 1.838830] WiFi driver (Powered by Rockchip,Ver 4.70.WFD.OOB) init. ... [ 2.011422] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.011474] ov5640_front_3(rk_cam_sensor:158): write reg(0x3008, val:0x80) failed, try to write again! [ 2.011936] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.012386] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.012847] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.012900] ov5640_front_3(rk_cam_sensor:158): write reg(0x3008, val:0x80) failed, try to write again! [ 2.013368] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.013823] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.014283] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.014334] ov5640_front_3(rk_cam_sensor:158): write reg(0x3008, val:0x80) failed, try to write again! [ 2.014397] ov5640_front_3(rk_cam_sensor:374): write array failed! [ 2.014433] ov5640_front_3(rk_cam_sensor:656): soft reset failed [ 2.014440] [ 2.029288] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.029855] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.030418] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.030473] ov5640_front_3(rk_cam_sensor:324): read reg(0x300a val:0x0) failed, try to read again! [ 2.030538] ov5640_front_3(rk_cam_sensor:683): read chip id failed [ 2.030665] rk_cam_cif(1618):WARNING drivers/media/video/rk30_camera_oneframe.c_rk_camera_mclk_ctrl_1618: camera sensor mclk maybe not close, please check!!! [ 2.030754] get cif ldo failed! [ 2.030773] ret: 0 [ 2.058950] camera 33-0-ov5640_front_3: Probe ov5640_front_3 failed [ 2.059051] get cif ldo failed! [ 2.059072] ret: 0 [ 2.089002] get cif ldo failed! [ 2.089023] ret: 0 [ 2.129019] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200 [ 2.129402] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.129763] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.130132] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.130187] gc2035_front_4(rk_cam_sensor:158): write reg(0xfe, val:0x50) failed, try to write again! [ 2.130558] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.130920] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.131278] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.131332] gc2035_front_4(rk_cam_sensor:158): write reg(0xfe, val:0x50) failed, try to write again! [ 2.131707] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.132080] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.132438] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.132493] gc2035_front_4(rk_cam_sensor:158): write reg(0xfe, val:0x50) failed, try to write again! [ 2.132559] gc2035_front_4(rk_cam_sensor:374): write array failed! [ 2.132596] gc2035_front_4(rk_cam_sensor:656): soft reset failed [ 2.132606] [ 2.149194] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... [ 2.149666] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... [ 2.150142] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... [ 2.150196] gc2035_front_4(rk_cam_sensor:324): read reg(0xf0 val:0x0) failed, try to read again! [ 2.150263] gc2035_front_4(rk_cam_sensor:683): read chip id failed [ 2.150363] rk_cam_cif(1618):WARNING drivers/media/video/rk30_camera_oneframe.c_rk_camera_mclk_ctrl_1618: camera sensor mclk maybe not close, please check!!! [ 2.150449] get cif ldo failed! [ 2.150469] ret: 0 [ 2.178928] camera 33-1-gc2035_front_4: Probe gc2035_front_4 failed [ 2.178994] ANDROID-ERROR) wifi_set_power = 1 [ 2.179027] rk29sdk_wifi_power: 1 [ 2.432590] wifi turn on power [ 2.638777] ANDROID-ERROR) wifi_set_carddetect = 1 [ 2.638837] rk29sdk_wifi_set_carddetect:1 [ 2.638872] mmc1: slot status change detected(0-1) ...
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by Sarvesh View PostI will suggest to post your comments in newbies forum
Sent from my GT-N7100 using Tapatalk
Sound delayed online tv
Hi
I flashed the ROM on a MK908II today.
Streaming videos from NAS seems to be good.
But on tv streaming (with the zattoo app) the sound is delayed about 0.2-0.3 seconds. It's not much, but you see it and it sucks... on a "old" MK808 with Android 4.2.2 there is no such problem.
Anybody the same problem? Any solutions? Maybe another kernel helps (the OC or another one with better performance)?
Damian
OK, just installed this on my QX2.
No need for bootloader unless as not clear that is only for the cx-919 model?
no need to use the dodgy usb plug supplied as they are not to uk specs, mine uses the tv usb port very well and along with the hdmi cable, nice and neat.
Is there anyway to change bootup screen so it does not display the cx-919 logo but the imito qx2 logo?
I will test this rom for few days before any further questions
Thank you kindlyLast edited by Wingchundub; 08 June 2014, 16:22.
There are currently 2365 users online. 3 members and 2362 guests.
