NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Crackle not compatible
I'm using this rom on an older CX-119 with D33's v4.1 tv stick kernel. Everything works great except the play store reports that the Crackle app is not compatible. With Finless 1.6b it is compatible and works fine. Both devices show as GT-19300 in the store settings. Could someone suggest how to resolve this? Is it due to some difference in build.prop?
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by Bock View PostI'm using this rom on an older CX-119 with D33's v4.1 tv stick kernel. Everything works great except the play store reports that the Crackle app is not compatible. With Finless 1.6b it is compatible and works fine. Both devices show as GT-19300 in the store settings. Could someone suggest how to resolve this? Is it due to some difference in build.prop?
Originally posted by kbgbef View PostGeekbuying has uploaded a working ROM for the original MK908 v1 here - http://blog.geekbuying.com/index.php...nd-v3-version/. FinlessBob, could you please patch the kernel to native 1080 ?
Thanks.
Here ya go:
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by mechaone View PostI ran into the same issue with my stick on Neomode 1.9a. Dont know if it was simply because the stick reports its self as an MK908, or there were extenuating factors. Tried using an Xposed framework plugin to fix the issue. They would then show in Play Store, but would hang before install. I now use 1mobile market to load apps that the Play Store won't provide.
Here ya go:
1mobile.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf 1mobile.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
rk3066 dual core a9 processor not working
hi there. im new this forum,
i have a problem on my mini tv android dual -core A9 processor RK3066
does any know something about it please cause when i insalled it on my tv it just showed up the logo android and then its gone and the screen stayed black.
i need a new program for it ?
thanks alot
thanks alot
The rom works perfectly on my tronsmart cx-919 but the hd video playback is frame skipping.
In addition since i flash this rom I can't go back to 4.2.2. I get an error on Checking download data
Code:12:27:02 864 INFO: Download files to flash finished,Total(492060304)B 12:27:02 864 INFO: Start to check data 12:27:02 874 INFO:Start to check download data 12:27:02 934 Info:RKA_File_Check start,file=misc,offset=0x2000 12:27:02 954 Info:RKA_File_Check start,file=kernel,offset=0x4000 12:27:03 494 Info:RKA_File_Check start,file=boot,offset=0xa000 12:27:03 644 Info:RKA_File_Check start,file=recovery,offset=0x12000 12:27:04 324 Info:RKA_File_Check start,file=system,offset=0x484000 12:27:27 254 Error:Compare system file failed,Offset(365953024) 12:27:27 414 Error: Check system file failed 12:27:27 414 ERROR:Download file failed 12:27:27 424 ERROR:Image Thread Failed 12:27:27 434 ERROR:Run failed
Originally posted by johniem View PostThe rom works perfectly on my tronsmart cx-919 but the hd video playback is frame skipping.
Originally posted by johniem View PostIn addition since i flash this rom I can't go back to 4.2.2. I get an error on Checking download data
JB needs 1.24 version whereas KK would work with 2.07 onwards (somebody correct me if I am wrong). KK on my CS968 does works with 2.13. Here is the complete list (pick ones for RK3188).
Looks like you have bricked your device and need to open it and short some pins to unbrick it. Exact pin numbers will depend on your device model/make.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
There are currently 2017 users online. 0 members and 2017 guests.
