$169, but that's literally the Galaxy S4 on a PCB. Worth it if you need the power.
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by jacobsson View Post
$169, but that's literally the Galaxy S4 on a PCB. Worth it if you need the power.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by ididmytime View PostIf you need a better performance device, you might want to get an ODROID-XU.
I'll really consider the odroid for my next project. For now I'll try to make the best out of this little guy, tbh I didn't plan to do any dreamcast emulation from the beginning
My final goal is now, as said earlier, to have the cx919 perform close to 100% for the N64.
Up next is to learn how to achieve custom OC!
Skickas från min iPhone via TapatalkPIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
Originally posted by jacobsson View PostHi Ghan!
How can you determine if it gets dangerously hot or not?
I have a CX-919 and I don't think there is any temp sensor integrated in the chipset that can be read, how about yours? I'm using a external mounted fan and I'm planning to OC my stick to galaxy S4 performance.
Yes, its difficult to quantify. But I take it dangerously hot if it feels very hot in my hands. In my case, it was a bit hot (with this ROM/D33 kernel) than warm (with stock ROM). No sensor on mine too, I believe.
I wanted to see where have you soldered the fan and if you screwed/glued the fan to the stick.
My stick seems to be unstable if Max is kept @1.8GHz, so I would not go beyond 1.6GHz I think. I also saw similar problems to somebody else who reported stick with no signal if left alone for some time.
Got Antutu score of 19055 with max @1.6 GHz. Not sure if the GPU/RAM is oc'ed in this HD kernel of D33.
Yours is stable @ such high Antutu score?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Just tested the v3.00 kernel and scored 22500, not sure if it's the lower res screen that did it, gonna redo it at my tv when I'm home
Yes, it's very much stable since I can run Reicast for as long as I want, I should maybe do the stability test i Antutu to be sure?
Regarding the fan mod: I have not secured it yet (only glued the cables after soldering). The fan is 'pushed' into place in the squared hole I cut out in the housing. I'm waiting for a high quality 0.5mm thick and sticky thermal pad that will hold it on place.
Originally posted by encore2097 View PostHi,
I have a CX-919 w/ AP6210.
I flashed this and 1080p kernel.
Wi-Fi is not working and neither is USB debugging.
Any ideas?Nikon D80 Photographer
Eye for the Art.
__________________________________________________ ________________________
CX 919 - Rockchip RK3188T 1.4 GHz & AP6210 WiFi ( Date 3-3-2014) + Tronsmart TSM01 Rom using: Testing.
Originally posted by deepspace View PostWith this Rom you must use original Finless Rom kernel... With my CX-919 this rom wasn't very stable... wifi goes off some times and it shut downs randomly.. I think it's an android core problem that's because they are rushing the update to kitkat 4.4.3.
What could be the difference between our sticks?
Could it be overheating? Try w/o casing.PIPO-P1@1.6GHz
Originally posted by jacobsson View PostHmm. I use the Finless 4.4.2 with D33's AP6210 V300 HD kernel and have no issues with wifi/BT.
Could it be overheating? Try w/o casing.Nikon D80 Photographer
Eye for the Art.
Originally posted by deepspace View PostThere are two versions of CX-919 one with the overclockable ARM3188 processor and one with the ARM3188T that is stuck @ 1.4Ghz
I hope it works out for you, also there is a "T"-version of D33's v3.00 kernel as well, tried it?PIPO-P1@1.6GHz
Originally posted by jacobsson View PostOh, sorry I missed the "T" in your signature!
But even with a 720p kernel with this rom I suffered, has i said before, some random shutdown... and over night the dongle turns off... or the screen turned off having no hdmi signal. Maybe I choosed badly the kernel... but for know I'll wait for more stable CX-919v2 Rom's & XBMC gotham also to be a stable release before changing everything to kitkat again.Nikon D80 Photographer
Eye for the Art.
Originally posted by deepspace View PostYep @ work with my 1080p monitor. But @ home my TV is HDready only 720p and that's a problem.
I too noticed that XBMC isn't very stable in KitKat, for me a stream can suddenly stop and crash to 'desktop' at anytime. Have you noticed this as well? That's the only problem I've ever encountered so far.PIPO-P1@1.6GHz
Originally posted by jacobsson View PostOk, what kind power supply do you have, is it a Chinese knock-off or a legit >2A 5V?
I tried both Finless and Neomode 4.4.2 kitkat roms and hadn't stability ... one of the reasons may be the kernel... but for what I know the core of kitkat have their one bugs that are soon to be corrected by 4.4.3 update.Nikon D80 Photographer
Eye for the Art.
Hi, i have a cx 919 with a 3188T.
Yesterday, i have installed the rom kitkat for T428, nothing i having a black screen.
I have test with this rom with kernel_AP6210_V300, kernel_t_ AP6210_HD_CIFS.
The rom is ok with my cx 919, the wifi is speed, it's all ok.
On my tv, it was too small, so i have installed the kernel_t_ AP6210_SD_CIFS!
My dongle stay blocked on finless 1.7.
I having reinstalled with kernel_t_ AP6210_HD_CIFS, and the cx 919 stay blocked on the writting in red finless 1.7.
What is solution for the kitkat with my cx-919 3188t?
2. For AP6210 with a TV Stick use one of these V3.0 KitKat kernels
3. Remember, If you wish to revert to a Jelly Bean ROM then you MUST tick the box for the v1.0x loaderMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 6438 users online. 0 members and 6438 guests.
