the rest works fine
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by abdul_pt View PostNo one ?
So you know the TV stick kernels are not using this area. It does not show up in the mount command like KK for tablets does. I believe this area is used for multi-user and encryption and TV sticks have yet to implement multi-user on KK.
R: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by lucap00 View PostIs this rom ok for this device? http://www.bosuntop.com/en_productsh...=5&cid=6&id=27
I believe yes because it has got the same hardware of other famous mini PCs, but I'm not sure.
sorry for my bad english, I'm italian.
Inviato dal mio GT-P5110 utilizzando Tapatalk
NEOMODE app doesn't work. I'm looking to get a working version soon
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by d33 View PostNEOMODE app doesn't work. I'm looking to get a working version soon
Sent from my HTC One
Unknown 3188 device
Originally posted by petro_ionut View PostThanks, i can hardly wait, because i don't know what is in my mk908II, RK3188 ot RK3188T.
I had the same issue and posed the question on another forum. I was simply told if it quacks like a duck and walks like a duck then it's probably a duck. I do wish however that I could find out for sure to help with testing other types of ROMS. The DMESG file also shows nothing but the full RK3188 on my system as well.
I look forward to testing D33 fixed program for checking on chipset types.
Thanks.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
Pls help
Originally posted by babnik80 View Posti tried the rom on my mk802iv ap6210. i found everything good, except one critical thing! antutu 3d score with everyoced kernel i tried goes only from 1200 with 798mhz to 1100 with 400mhz! don't know why! any ideas? bob what do you think? thanks!
can you tell us how to install it on mk802IV?
I get bootloop.
thanks in advance!
I fixed the boot loop problem affecting a few models last week. I'll post a new set of kernels when I get chance
Donate to Finless
installed on egreat cx919 works great !!
many thanks to mr bob for this rom, took me 3 days, 5 different computers, and a lot of hair pulling to get this rom installed. problem was couldn't get any computer to even detect device it was as though it didn't exist. Finally read that the original usb cable could have a longer metal socket than normal usb cables, seeing as i bought quite a few things together i didn't know which was the original usb but when i checked the one i was using was shorter than some of the others that i had. After than had no problem installing drivers on windows 7 and 8.0 though not on 8.1 still cant get it to install drivers on there. Been playing around with it all day don't see any problems, at first the image was too big for screen size using it on LG 3D 47" smart tv, went into reading about DPI settings and how to change them then found that zoom out worked, sometimes we make problems bigger than they are.
Anyway thanks to all you guys here for all the work you do.
I also bought the egreat rk3188 U8 tv box anybody know if there are roms out for that or which forum i should be looking in for them.
Donate to Finless
There are currently 2075 users online. 0 members and 2075 guests.
