Anyone else having problems to get the device to be recognized by ROM Flash Tool after updating to finless rom 2. Device manager shows up as GT-i9300
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by SkipTracer View PostAnyone else having problems to get the device to be recognized by ROM Flash Tool after updating to finless rom 2. Device manager shows up as GT-i9300
What do you want it to say?
Signature? Signature!
Signature? Signature!Last edited by SkipTracer; 15 March 2014, 09:19.
Originally posted by SkipTracer View Postsorry guys, i needed to reboot to bootloader. sorry for being such a noob
Originally posted by JugsteR View PostI'm sorry, I misunderstood you. Normally it says that and yes to get that software to recognize it you have to be in boot loader mode.
Originally posted by SkipTracer View PostI fashed it again with with kernel_T_AP6210_SD.img and now its hanging on a screen "A finless bob rom 1.7 Minix" went back to back to kernel_T_AP6210_HD.img and its working again.
Sent from my HTC One
Hi. Can anyone help me. I cant use any of the over clocked kernels. It booted up once then reset to the linux penguins. Works fine with stock though. Dont think my cx919 is the t version because ive had it awhile, i might be wrong tho. I ran an app it say it wasn't the t version. Opened it up its ap6210 tod6002 1324. Running at 1.6 ghz works fine when I flashed an .IMG file jellybean ROM. I'm tearing my hair out ready to throw my stick at the wall. Thanks in advance. Rob..... Sorry to post this again just thought I'd double my chances of someone reading it...
Originally posted by b0bby View PostHi. Can anyone help me. I cant use any of the over clocked kernels. It booted up once then reset to the linux penguins. Works fine with stock though. Dont think my cx919 is the t version because ive had it awhile, i might be wrong tho. I ran an app it say it wasn't the t version. Opened it up its ap6210 tod6002 1324. Running at 1.6 ghz works fine when I flashed an .IMG file jellybean ROM. I'm tearing my hair out ready to throw my stick at the wall. Thanks in advance. Rob..... Sorry to post this again just thought I'd double my chances of someone reading it...
Cheers!
I tried beta2 with one of Finless' new 1080p OC kernels (the one he recommended in the Readme, can't recall) and d33's kernel (the 1080p one for the "T" model). They did not run well at all, movement was extremely choppy. I went back to d33's kernel_AP6210_FHD.zip and now everythign is considerably smoother. Just a heads-up.
I suggest you try the Kernels posted in the "Kitkat Kernels for all" thread.
They're improved and I'm posting newer ones occassionallyMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Indeed they are, they work much better. Only thing is, after installing a couple of apps I installed AnTutu and did a stability test. After that I installed its OpenGL ES 2.0 module and then the air mouse became jerky as all hell. Can't complain though, aside from that it works great. Thanks.
Originally posted by Sarvesh View PostYes. .. You can try that. ...
I m wondering what my device is.. This rom worked for me.. I am also use to some 802iv roms... they work for me... so I guess it should work for you...
Sent from my GT-N7100 using Tapatalk
the specs are RK3188 quad core 1.8 ghz, 2 gb ram ddr3, AP6210, gpu mali 400MP, nand flash 16 gb.
I flash only one Rom over the stock NEOROM 1.9 but i have no wifi and no bluetooth.
Now i'll try finless 2.0 and i'll see...
Tomorrow i tell you what happen, if works or not!
There are currently 3238 users online. 0 members and 3238 guests.
