NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Bluetooth
Hi Guys,
I'm on an Imito QX2 and running Bob's fine Finless 2.0 beta. I have some issues:
-the device tends to "hang" when updating apps. It does literally freeze and sometimes reboot. (I try to run updates during the nights when it would be idle...);
-I have BAD bluetooth connectivity. I have a mouse, a keyboard and a GamePad from which mainly the mouse is connected. I am sitting 2m-s from the TV (the device is behind the TV because of a really short HDMI cable) but the cursor has HUGE lag. I have tried to change the batteries in the mouse but nothing. The same applies for the GamePad. So it must be - in my opinion - something with the stick. Could the TV shield the bluetooth signal?
How is it possible:
-to control the stick from another android device from the same network (from the same room)?
-from another network (starting a torrent from a restaurant...)?
-mirror my android device's screen or share it's contents?
Thanks in advance!
To control your device with another android device via wifi: droidmote. Rkcontrol does not work on this Rom.
Control from another network/mirror screen: I dont know.
Thanks in advance!
hey Bob,
Are you able to give a status report on this ROM for us unlucky 3188t owners?
d33 released a kernel which seems to work well with your ROM and fix most (all?) of the performance problems, but I would like to hear your comment on this.
Also, have you been able to find out how to reenable rkRemote and wireless display?
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Sent from my GT-I9505 using Tapatalk
No I have not stopped.... just was a busy week and now working on TWRP with Abdul to make that a sweet present for you guys
I am having screen flashing/flickering issue so I just finished flashing finless 4.4.2 rom (both with finless kernel as well as the other kernel -kernel_AP6210_FHD.zip by d33 - in the same thread) but although the flashing is less frequent it is still an issue. Specially when i go to say app store but when on homescreen it rarely occurs and as soon as i open app store it happens every other second. I am using 720 - 60 hdmi resolution (tried all of the various res options). Any idea?
new rom for MK908I
Originally posted by Finless View PostNo I have not stopped.... just was a busy week and now working on TWRP with Abdul to make that a sweet present for you guys
I have a CX-919 II 6330 and I need a working 4.4 ROM
Originally posted by d33 View PostT428, and other AP6330 stick users, users can test using this kernel -> [ATTACH]4716[/ATTACH]. It gives an Antutu score of 22,000. Unfortunately it has a HDMI output problem that limits it to 720p, at least it does on my kit.
I can compile an overclocked AP6210 from source if anyone is interested?
I have a CX-919 II 6330 QC-A9 BT-4.0 CPU-1,6-1,8 gpu400 2gb ram 8gb rom. After installing some 4.4 Kitkat Roms my wifi wasn't working and without connection to internet I couldn't change the kernel. I think that I need a ROM with kernel suitable for 6330.
I couldn't find anyware. Please help me! which Rom should I use and which kernel.Last edited by Yerbol; 19 February 2014, 16:20.
I have finally run this rom on my CS968, but with a kitkat kernel found here http://www.freaktab.com/showthread.p...2-for-Minix-X7 for the ut1 device. But wifi is not working!
Tried more than 10 different kernels for AP6210 but non works for my device! Anyone can help?
sleep mode
i have sucessfully updated my MK908ii to this rom. I did turn on sleep mode in settings, how can i disable this because when it goes to sleep the only way i found to get back is to unplug power.
Thank you for the help.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
There are currently 1981 users online. 2 members and 1979 guests.
