Sent from my mobile device. Please excuse any typos.
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by noderat View PostIf you've had a problem first blame your USB cable. I've found 9/10 times it's a crappy USB cable with high resistance that causes errors flashing. Thankfully I've never had to short pins myself - I've been lucky enough to have mine mysteriously find its way into mask ROM mode by multiple connection disconnection attempts.
Thanks!Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by ghanashyaml View PostYes, I thought so, so I was trying with the USB cable that came with it and other chinese USB cables I had. Let me try today with a cable that came with my Nexus 4. That should be of good quality.
Thanks!
Originally posted by petersen77 View PostMy Samsung cables are always faulty after some months. Not the best mechanical quality. Now I use nylon cables which are better.
gesendet von meinem Samsung Knochen
Originally posted by noderat View PostSounds like a good plan! I personally always use short 2ft Samsung USB cables when I flash as I know they have low resistance and always flash successfully.
So the question remains if the boot loader in this ROM is incompatible with my CX 919 II. I have attached a snapshot of the board.
Anyone with similar board has success with this ROM, before I retry?
I need to get a good ROM/Kernel to avoid the choppy videos that I see now. I saw someone mentioning 20000+ with some other ROM?Tronsmart Orion R68 Meta
Originally posted by ghanashyaml View PostI saw someone mentioning 20000+ with some other ROM?
I scored 22064 yesterday, but I have a regular CX-919. I use the Finless 2.0 ROM with latest v207 kernel.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
Originally posted by jacobsson View PostIt might have been me?
I scored 22064 yesterday, but I have a regular CX-919. I use the Finless 2.0 ROM with latest v207 kernel.Tronsmart Orion R68 Meta
Version 3 kernels now published
Main change is GPU now unlocked for 'T' CPUs and DDR unlocking fixed for all 'T' variantsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
d33, great work with all your roms. I have flashed finles 2.0 with all your kernels including the one you just posted i.e. 3.0 (also i see 3.10 in progree - will try that as well). But I have been getting this flashing/flickering hdmi issues with all sort of roms/kernel i have tried. It seems there is a solution but for linux: https://www.miniand.com/forums/forum...-solved?page=1
Can you please prepare a kernel with above fix for android only? Pls pls pls ?? BTW I have a MK908 II T-variant of the stick.
I know its a kernel issue coz while its booting up, it flashes, while in recovery mode it flashes so it has to be a kernel issue. Waiting for your reply.
Originally posted by freakbrave View Postd33, great work with all your roms. I have flashed finles 2.0 with all your kernels including the one you just posted i.e. 3.0 (also i see 3.10 in progree - will try that as well). But I have been getting this flashing/flickering hdmi issues with all sort of roms/kernel i have tried. It seems there is a solution but for linux: https://www.miniand.com/forums/forum...-solved?page=1
I know its a kernel issue coz while its booting up, it flashes, while in recovery mode it flashes so it has to be a kernel issue. Waiting for your reply.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
HELP
Boot 720p with large icons anyone?!
Im using T428 Finless 2.0 KK ROM with D33 kernel_t_AP6210_SD_v310.img I tried many choices but the icons still are too small.
Tryed the boot.img from cx-919 rom
Tryed the boot720.img from T428 rom (using)
Tryed the boot 1080_large .img from T428 rom with D33 kernel_t_AP6210_HD_v310.img but my TV is HDReady it messed up.Nikon D80 Photographer
Eye for the Art.
__________________________________________________ ________________________
CX 919 - Rockchip RK3188T 1.4 GHz & AP6210 WiFi ( Date 3-3-2014) + Tronsmart TSM01 Rom using: Testing.
There are currently 1769 users online. 0 members and 1769 guests.
