NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
    I have no slowness with Kit katt but I do have issues wth google play app not working. Will reflashing tomorrow see how it goes
    Sent from my iPhone 5 using Tapatalk
      Originally posted by carloscristo View Post
      I'm still finding courage to flash the 4.4.2 finless rom.. becoz a lot of users report sluggish UI, and not always correction of the flickering and black-out problem (I only have this problem with the Sony's HT: BDV-E985W)..
      Hi Carlos!, thanks for sharing your experience. Kitkat 4.4.2 seems to be much faster and snappier for me with all the ROMs I have tried. The blackout problem (video that I recorded with the blackout http://youtu.be/uwsTG0I5aZI) seems to be specific to my CS968 and no one else with the same MOBO have reported this. So I feel it might be my TV (chinese Hisense brand )...Tonight, I will test with my bedroom TV and see how it goes.
      The latest D33 Kitkat 4.0 kernel was the first one without any frequent blackout (saw one in an hour or so but much better than before).
      How did your 4.4.2 flashing go?
      Tronsmart Orion R68 Meta
      CS968 -> HTC_T018 v4 20131216 with MTK
      GM282 (aka CX 919 II aka J22) - dead
        sound
        in my mk908ii the sound is too loud there are no steps in sound settings,is there a problem with the rom?
          This is a beta so sound didn't work correctly.
          Use one of the tronsmart roms they are fixed and you can par them with a kernel that works for you.
          Think yours is the 6210 chipset so these kernels should work http://www.freaktab.com/showthread.p...8well-most!%29
          Mk802IV Neomode 1.9a original rom 720p
            Hi ghanashyaml!!
            Sorry for my delay!!
            Good to know your experiences too!! And seems you're right! KK disapointed me.. when I tryed the "original" finless rom 2.0 kk 4.4.2 .. antutu showed me just 12000 points.. (i checked with cpuz that my rk3188 was only 1.2Ghz)...
            So I kept my 1.5a (antutu 18400) and tried the good rkpatchomatic by phjanderson.. me best result was using 1700 on cpu, stock on gpu and 667 on ddr... then i got 18759. (I like 1.5 becoz it has all I need.. and shutdown, vol and full screen buttons).
            Well.. the curiosity spoke louder.. so I tried the 4.4.2 with the new kernels suggested by Magnus33 (http://www.freaktab.com/showthread.p...8well-most!%29). And good news... even in 1080p (i always used 720p)... it recognized my mk908II with 1.6ghz and antutu happily showed me 19018!! Now I can carry on with you question... tonight I'll do some more tests.. and try to overclock just a little like the 1.5a.
            And about the blackout.. I'm wondering if the PSU can really be the problem.. becoz all the million roms I tried never show me a stable image (tried 2A and 2.1A PSUs).. but i noticed that when I start the MK908II naked... the flickering is less than when I connect the USB dongle (for mouse and keyboard).. that means.. when the PSU has more childrens to feed. I will try to find a 5A (or above 2 or 3A), ok??
            And thanks for the D33 Kitkat 4.0 kernel info!! Plz.. where did you find it??
            More things to try.. lol.. cool that this never ends! : )))
            Tronsmart MK908II RK3188(non-T)
              hi finless,
              I installed this Rom szy_rk3188_x6 devices. Ap6210 WiFi + BT worked. but Usb ports do not work.
              OTG port is working.
              I plugged in the mouse OTG port.
              How can I active the other USB Ports.
              My device's Picture (rk3188_box_szy_x6 v1_0 131024)
                Make firmware for Imito QX1 please.
                  Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
                  Hi Finless,
                  A couple of months back you mentioned you were working on something exciting for these devices. Has this come to an end?
                  Sent from my GT-I9300 using Tapatalk
                    szy rk3188
                    update
                    Originally posted by endera View Post
                    hi finless,
                    https://disk.yandex.com.tr/public/?h...Xuw84UMqduk%3D
                      Hi Finless, great ROM. I need your help, I want to modified a stok MK902 KK rom to make it 1080p but I think they changed the binary, to you have a binary patch to enable real 1080p?
                      Thank you
                      For all your computer problems...
                      http://www.salvamipc.es
                        Rk3188T
                        Will this work for the Tronsmart MK908ii RK3188T? it does have the same Wifi chip.
                          AW: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
                          Yes, it does.
                          But I would suggest you to use this ROM:
                          And the kernel t_3.0_AP6210 from here:
                          This works pretty well for my mk908ii.
                          And the kernels from d33 equalisize the problems with 3188t kernel
                            RK8133T
                            Originally posted by norbert6 View Post
                            Yes, it does.
                            Thanks for the reply the ROM that came with it doesn't work with my AppRadio. Ive been using iOS for years this is my first android, so rooting is new to me. Does the Flash exe work in Windows 8.1?
                              the flash tool should work but I'm not sure I've seen any report of anyone getting the drivers for the device working win8.
                                CX919
                                Hi Bob,
                                Thanks for this awesome ROM (adult beverage is in your inbox). I'm using this ROM and one of D33's and noderat's OC kernels on my CX919 that I bought last summer. I consistently get Antutu scores well over 22,000. This is the first combination that I've found that completely removed the screen blanking on my old HD ready plasma TV. I have only encountered a couple of issues so far - by default, keyboard hardware is always on, and since normally don't use keyboard hardware, every time I boot I must modify that setting. Also, the link to Google contacts is broken. I'm sure you are aware of these two relatively minor issues.
                                Do you plan to update this awesome ROM?
                                Thanks again!
                                Mark (exibm)
