Will it work with XT-Q7-V10 TV box?
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
How to sign into KK after reboot?
OK - I flashed this ROM on my CX-919ll rk3188T and when setting things up with Android it rebooted so my question is: How do I sign in when the mouse or keyboard will not move the arrow to the right to sign into Android KK? This is designed for a touch screen of course so how do I get this done when using with a TV?
Do I have to re-flash it and start over and hope to get through enough of the setup to change settings to use a PIN to sign in?
Originally posted by codger64 View PostOK - I flashed this ROM on my CX-919ll rk3188T and when setting things up with Android it rebooted so my question is: How do I sign in when the mouse or keyboard will not move the arrow to the right to sign into Android KK? This is designed for a touch screen of course so how do I get this done when using with a TV?
Originally posted by jpservices01 View PostDon't you have a USB mouse?
Originally posted by codger64 View PostYes I have an airmouse but the mouse cursor doesn't show up on screen until you get past the sign in screen (the screen with the arrow within a circle). So how do I move the arrow within a circle icon to the right to sign in?
Hope this helps.
Originally posted by jpservices01 View PostAirmouse? Are you suggesting this is a bluetooth or some kind of wireless? Try a wired USB mouse, move passed the security screen, connect your air mouse and then next time you reboot you should be good to go...
Hope this helps.
Updated Beta Version released
Hi There Finless,
I have been enjoying your roms for this device for a while now, including this one.
I recently read on Geekbuying's blog that Tronsmart have released an updated Beta about 3 weeks ago,
and I'm wondering if you plan on releasing an updated Beta of your own based own this new release please?
Would be wonderfull if at all possible.
Keep up the good work fella!
I have now introduced a few mates to your custom roms and they are loving it over their stock versions
Originally posted by mo123 View PostWhy don't people use stable stock KitKat AP6210 ROM's?
This is still a beta ROM.
http://pan.baidu.com/s/1pJwPYIn
If you build a new version of this ROM would it be possible to integrate the multitouch.ko that was made available a while back for version 1.4 of the ROM for the CX919?
This would be really great!
Works with MK908II
Hi here,
First, thanks to Finless for the rom. It works great on my Tronsmart mk908II.
I share the feeling that XBMC run better on this rom than the 4.2.
Some issue I expected :
- Volume control has only 2 positions : on (100%) and off (0%). Same problems using Yatse.
- RKremote control for 3188 doesn't works with this new rom.
I propose help to realize some tests if needed.
One more time, great job Finless !
Have a great day !
Have a great day !
I will say, I tried switching to another ROM to get volume control. It was fixed, but that ROM wasn't nearly as stable as this one. I will switch back as it's not worth it.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
Can't get Netflix to play on this ROM??
Hello - I can get my Tronsmart CX-919 (Ver. 2.0 on the board) Rockchip RK3188T chip to load this ROM but when I try to play anything on Netflix it locks up and I have to reboot. Any suggestions would be appreciated. It also sometimes locks up when I use the USB Airmouse / keyboard from GeekBuying.com. I have changed the power supply to a 5V 2.5 Amp regulated one and drilled holes on the case to help with the heat FYI.
Originally posted by codger64 View PostHello - I can get my Tronsmart CX-919 (Ver. 2.0 on the board) Rockchip RK3188T chip to load this ROM but when I try to play anything on Netflix it locks up and I have to reboot. Any suggestions would be appreciated. It also sometimes locks up when I use the USB Airmouse / keyboard from GeekBuying.com. I have changed the power supply to a 5V 2.5 Amp regulated one and drilled holes on the case to help with the heat FYI.
Be sure to run version 3.1 as this ROM is still BETA with no updates from the looks of the activity by the developer of it. Your device is using AP6210 for wifi so choose this.
This is the most stable ROM and Kernel combo I have tried. Only issue I have is there are no volume controls, but thats okay for me since I run it through a reciever anyways. I run Netflix, Beyond XBMC, Hulu, Pandora, MX player and much more with no difficulties. I also choose to use the SD over HD for the improved performance and I could see the icons better. AnTuTu score of 25450, wich is way better than stock at 17249.
Good luck.
Hi - thanks for your reply. I'm not quite sure what you mean by no volume controls? I will be using this with the Sony LCD TV in the bedroom so it won't have a surround amp hooked up to it. Will I not be able to use the volume control on the TV?? Also should I use the AP6210-alt or the regular AP6210? Which kernel should I use - I just want a stable video playback with no flickering, reboots, or lockups and I have no need to overclock it - so which kernel will make that happen please?
Originally posted by vxxozxxv View PostHello. Im running almost the same device the MK908ii with this ROM. You do need to make sure to load it with the kernel from D33. Here is the link -http://www.freaktab.com/showthread.php?11193-Kitkat-Kernels-for-All-(well-most!)
Good luck.
There are currently 1713 users online. 0 members and 1713 guests.
