NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
    Thank for your answer D33
    I have install my cx 919 with the rom T428, i have dl your boot.img and i have dl this
    kernel_t_ AP6210_HD_CIFS.img.
    And i have the small animat robot blocked!
    After i have instaled this rom "CX-919 4.4.2 Finless 2.0 BETA" with the kernel_t_ AP6210_HD_CIFS.img.
    I have a bug at the beginning with finless 1.7 (red) but the rom pass as the first time!
    Its 1080p but it's all ok. 720P, its not possible with my cx 919?
    I go dont test 720p but its hard to intall kitkat 1080p on my cx 919 with a ******* rk3188t.
      You should consider going to a 4.2.2 ... try finless 1.6 or neomode 1.9a
      Nikon D80 Photographer
      Eye for the Art.
      __________________________________________________ ________________________
      CX 919 - Rockchip RK3188T 1.4 GHz & AP6210 WiFi ( Date 3-3-2014) + Tronsmart TSM01 Rom using: Testing.
        Read the kernel thread, loads of overclocked kernels for t cpus
        Donate to Finless
          deepspace, i want kitkat because a apk for replay french tv, bug with 4.2.2.
          With kitkat is ok!
          I dont touch this version of kitkat, it works perfect.
          I wainting a new version for 720p!
          The small bug with kitkat on the beginning :
          http://img15.hostingpics.net/pics/378677cx919.jpg
            Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
            Originally posted by jacobsson View Post
            Excellent, thank you!
            Skickas från min iPhone via Tapatalk
            Originally posted by deepspace View Post
            It's Geekbuying 2A 5v pack that runs 24/7 with android 4.2.2 and with LG externel disk attached to it and @ this precise moment I even can remote VNC the gongle. And Yes the XBMC given me some troubles too. For know and until I read some more confident coments about CX-919 "T" Version with 4.4 I'll recomend 4.2.2 to everyone.
            I tried both Finless and Neomode 4.4.2 kitkat roms and hadn't stability ... one of the reasons may be the kernel... but for what I know the core of kitkat have their one bugs that are soon to be corrected by 4.4.3 update.
            The power supply supplied by geek buying is likely not actually supplying 2A. There is a power supply thread in these forums (I'd have to search for it) that has some great information. Personally I went on Amazon and searched for power supplies with good ratings and have had success. Also, is your external disk externally powered? Or is it just powered from the USB? If it can be externally powered I would recommend it.
            Edit: http://www.FreakTab.com/showthread.php?t=3805 there's the power supply thread.
            Sent from my Nexus 7 using Tapatalk
              Stay tuned all.... FreakTab has some exclusive for new KK coming.
              I am pretty sure you WILL like what we all are working on
                Why should I change charger if mine is working with LG directly to cx-919 for 24/7 without any problem? no reboots, no hangs, no nothing.
                You say the charger isn't supplying 2A, but that's what it says in the back of it, and I doubt your affirmation, if the problem was the charger or lack of Amps it would give me allot of problem's with all roms and at all time. That's not the case.
                Eye for the Art.
                  That's good news
                  Eye for the Art.
                    This sounds promising
                    Sent from my GT-I9300 using Tapatalk
                      I agree with both of you, but sometimes the components in 'cheaper' adapters they'll still produce the stated amps, but uneven voltage under load. Just look at the raspberry pi, it doesn't tolerate much fluctuation before random reboots occur, often results in corrupted SD-cards. Don't concentrate so much about the amps (2A should be enough), look for adapters that works good for the pi, or take the more expensive one.
                      EDIT: I use the stock adapter (which I can imagine varies depending on vendor), I'll check the model when I get home.
                        Anyone tested this new KitKat rom released yesterday, is it better than the Geekbuying one or the same?
                        KitKat_T010_AP6210_public_20140403, Geekbuying one was released 20140331.
                        Mirror - https://mega.co.nz/#!WgR0WCZC!UPxulf...8YLozyjv5BTcCQ
                        thanks to Max One
                        Edit: It has bootloader v2.13 and most Google apps, busybox and Broadcom AP6210 wifi.
                        If only someone knew how to communicate with all these people that upload new roms to Baidu it would make it so much easier to get the correct and newer roms for all our different devices.
                          http://pan.baidu.com/s/1o6ufGuQ
                          Heard it was crappy, look over at Neomode's kitkat thread, I might be wrong!
                            Hi
                            Do you guys know if this rom will work with a ug007b device?
                            I use neomode's 1.7 for now.
                            Sent from my LG-D802 using Tapatalk
                              Originally posted by SPM View Post
                              Hi
                              yes, it will work
                                Thanks for the quick and good news.
                                Hope the HLS videos will play better in either xbmc or an external player..
                                I will know soon anyway
