Could you kindly support this adapter in next version/release?
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by dkdkdk View PostHi, any thoughts on how to add drivers for USB-LAN Edimax EU-4306 to this great ROM? Recompile only or other way?
Please report back your findings - kernel is 1.8/600/720 for RK3188 and 1.4/446/460 for 'T'
Res is 1920x1080Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Latest kernels are temporarily posted here for both T and normal CPUs
https://www.dropbox.com/s/74pnmyznay...nes_v01.02.zip
The 'T' kernels are without CPU/RAM override and can be patched to what you wish - 1.4/446/460 as provided.The normal kernels are 1.8/600/720.
Added USB ethernet support
Added full NTFS support - multiple partitions
Donate to Finless
New user reporting anomalies with Finless 2.0 KitKat 4.4.2
I am new to the world of roms and tv sticks so please pardon any apparent ignorance.
I've recently flashed the CX-919 Quad Core RK3188 and when I try access downloads I get:
"Unfortunately, the process android.process.media has stopped"
Not sure what to do, I'm trying to download the latest nightly build of XBMC.
In addition wifi seems to cap at 3mbps.
I have the stock kernel supplied by finless flashed, nothing overclocked. THe parameter file is 4gb.
Plex video repeatedly plays and freezes and is slow loading.
Any help would be GREATLY appreciated, thank you.Last edited by betelgeuse2112; 24 February 2014, 07:03.
Black screen lock up
Originally posted by vxxozxxv View Posti have sucessfully updated my MK908ii to this rom. I did turn on sleep mode in settings, how can i disable this because when it goes to sleep the only way i found to get back is to unplug power.
Thank you for the help.
I have found that this is not a function of sleep mode. After the system sits idle for a long time the display goes black and I cannot recover it by moving the mouse or clicking. I end up having to remove the power and plug it back in to restart.
Can you please tell us if this is a known issue with 2.0 ROM, or is there some other setting I may need to change.
Thank you for your response.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
Originally posted by Solyomszem View PostThanks, Balázs
Have anybody experienced any lag while there is network traffic through wifi? I do experience huge lag in mouse movement while downloading from YouTube or downloading apps. It's it related to rom?
What kind of PSU do you use?PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
A pardon
Originally posted by shtrampbakzen View PostHi I'm looking for step by step instructions on how to install a different ROM on my cx-919 its currently running the 4.2.2 that it came with and I'm curious what I all need to do to get this ROM installed?I've never done this lol thanks in advance
Please tell what happens if you remove power and turn it on again?
Originally posted by marko33 View Postcant get it to work on my 908ii, boots ok but no signal on tv after selecting keyboard language, dont know if the stick has turned off or what. left it for a bit to see if it reboots on its own but nothing happens.
I do not recognize this problem. I cannot think of another cause than a crash at every same moment. You could try to redownload the ROM and reflash it, maybe something went wrong during flashing?
Originally posted by marko33 View Postif i remove power and turn on again it does the same thing, gets as far as selecting keyboard language and then no signal, gone back to Finless 1.5a for now.
There are currently 3739 users online. 1 members and 3738 guests.
