NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
I did try erasing IDB with the finless kitkat tool then flashing through the other neomode rom's flashing tool with 1.20 bootloader but it gave me the same problem as before. The device becomes unrecognized and I have to short the NAND pins and reflash finless kitkat rom to bring the device back to life (it won't even flash stock rom with rockchip batch tool). After flashing kitkat rom, I am able to flash the stock rom (2.07 Bootloader) with the batch tool but I'm never able to flash neomode's roms (1.20 Bootloader).
Originally posted by shyguy View PostI did try erasing IDB with the finless kitkat tool then flashing through the other neomode rom's flashing tool with 1.20 bootloader but it gave me the same problem as before. The device becomes unrecognized and I have to short the NAND pins and reflash finless kitkat rom to bring the device back to life (it won't even flash stock rom with rockchip batch tool). After flashing kitkat rom, I am able to flash the stock rom (2.07 Bootloader) with the batch tool but I'm never able to flash neomode's roms (1.20 Bootloader).
Remember to install the correct drivers. If not successful, try another pc (worked for me)
I'm currently using this ROM with Darrell's kernal on my Tronsmart MK908ii. I just ran a broadband speed test and got ~2mb/s. I used the same app on my phone and got ~20mb/s (galaxy s4).
Both are in the same room using the same WiFi. Can anyone explain the Android TVs poor score??
Sent from my GT-I9505 using Tapatalk
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by Bazmamfoo View PostI'm currently using this ROM with Darrell's kernal on my Tronsmart MK908ii. I just ran a broadband speed test and got ~2mb/s. I used the same app on my phone and got ~20mb/s (galaxy s4).
Someone else was using bandwidth at the time your stick did the test. The stick is behind an electronic device (ie TV). They are using different frequency bands. They are connected with different rates. The engineers behind the stick did not have the same radio budget as Samsung.
The list really goes on...
Signature? Signature!
I was able to successfully flash this ROM on my MK908. The display is bigger than the TV and I need to reduce the scale. On previous ROMs, I would create the '/sys/class/graphics/fb0/scale' file with a value of 95. Is this still valid ?
I am unable to create the 'scale' file. It does not exist. Looks like /sys is mounted rw, but it is not allowing me to create the file.
root@m0:/sys/devices/platform/rk-fb/graphics/fb0 # mount
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /sys/fs/cgroup tmpfs rw,relatime,mode=750,gid=1000 0 0
none /sys/fs/cgroup/memory cgroup rw,relatime,memory 0 0
/sys/kernel/debug /sys/kernel/debug debugfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/secure tmpfs rw,relatime,mode=700 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
/dev/block/mtd/by-name/system /system ext4 ro,relatime,user_xattr,barrier=1,data=ordered,noau to_da_alloc,discard 0 0
/dev/block/mtd/by-name/cache /cache ext4 rw,nosuid,nodev,noatime,nodiratime,user_xattr,barr ier=1,data=ordered,noauto_da_alloc,discard 0 0
/dev/block/mtd/by-name/userdata /data ext4 rw,nosuid,nodev,noatime,nodiratime,user_xattr,barr ier=1,data=ordered,noauto_da_alloc,discard 0 0
/dev/block/vold/31:10 /mnt/internal_sd vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,g id=1015,fmask=0002,dmask=0002,allow_utime=0020,cod epage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
Thanks.
Originally posted by kbgbef View PostI was able to successfully flash this ROM on my MK908. The display is bigger than the TV and I need to reduce the scale. On previous ROMs, I would create the '/sys/class/graphics/fb0/scale' file with a value of 95. Is this still valid ?
Thanks.
/sdcard <= (any_bigger_than_8gb_device)
ROM works fine with kernel_AP6210_FHD.
I'd installed my noname gamepads through /sys/usr/keylayout .
I need now to connect my real sdcard to /sdcard to install big games.
Also i want have an opportunity to connect usb-hdd to /sdcard to have MORE GAMES.
And i miss the volume control buttons.
Thanks.
There are currently 3816 users online. 0 members and 3816 guests.
