NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Test AP6210 ->Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Originally posted by darrellr View PostT428, and other AP6330 stick users, users can test using this kernel -> [ATTACH]4716[/ATTACH]. It gives an Antutu score of 22,000. Unfortunately it has a HDMI output problem that limits it to 720p, at least it does on my kit.
I can compile an overclocked AP6210 from source if anyone is interested?
Signature? Signature!
Originally posted by JugsteR View PostHow do you change clu & ram speeds?
Signature? Signature!Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by JugsteR View PostThanks, I was talking more specifics.
I'll figure it out.
Tables are at the bottom of the source file and its all pretty obvious. Check defines to make sure you amend the correct table/source.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Nick N View PostSo I have a J22 RK3188 stick (same as GM282), flashed this ROM and now I have no Bluetooth or Wifi. At this point what are my options to get it to work? Maybe a different AP6210 kernel? How do I flash just the kernel using the tool?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Max One View PostYeah unbricking was easy, on my stick i had to connect pin 7-8.
And which stick was it, same as mine? Did u managed to install kit kat already?
lewy20041 or MaxOne...Do you know if this unbricking method will also works for the CX-919 v2.0?
Can you post a detailed procedure and a picture to see these two 7 and 8 pins?
The round dot in the corner specifies pin 1. That's what the dot is for.
That's because it isn't made for 919-ii
There are currently 2381 users online. 2 members and 2379 guests.
