No worries... Just tried to flash now it says unable to mount cache and metadata (invalid argument) Its formatted the rest but it looks like I'm stuck with the old ROM I had. (Katsy KitKat Rom) any thoughts?
Pipo M9 Pro RileyROM 2.5.2 KitKat
No, that isn't necessary. Just make sure you leave the loader (top item) checked when you flash the first time.Randy
Originally posted by jameswalker457 View Post
Edit.... flashed again and I'm back to kitkat... same problems with the metadata. What does it say as version to confirm I'm on correct one? I'm pretty sure I'm not as I havent got your usual crazy boot animation
Originally posted by Dutchoak View PostI'm testing this ROM right now on my M9 Pro. Flashing went like a breeze; rebooted like a charm. I notice it expects 3G signal on my wifi tablet... Now installing essential apps. Will come back for further testing results.
ART runtime
Has anyone tried the ART runtime? work OK?
-EDIT-
With all my questions I forgot to say a big THANKS!! I'm really excited to have the latest build of android on my tablet and in the few minutes I've been setting it up I can really notice a big performace boost in comparison to 4.2.2, Thanks Riley for all your workLast edited by the5th2000; 05 January 2014, 03:43.
You may get an error in recovery, but when the tablet boots into the system, you should have the KitKat ROM.
Did you erase IDB before you flashed? This is a necessary step whenever you change to a different ROM.Randy
Originally posted by rrileypm View PostYou may get an error in recovery, but when the tablet boots into the system, you should have the KitKat ROM.
I've been having problems with the IDB... It counts up to the 16 odd k then says complete... From there is says 0 out of 6 total but it still flashes okay... Any recommendations on that? My roms still flash okay.
I'm using the correct cable too.
Yeah, I noticed that, too.
You should be good, if the ROM flashed OK.Randy
There are currently 2507 users online. 0 members and 2507 guests.
