My mistake, now I get it .... Sorry
Pipo M9 Pro RileyROM 2.5.2 KitKat
I'm glad to hear from a satisfied user!!!!!! Thanks!!!!!!
Sent from my M6 using TapatalkRandy
Originally posted by netRAT View PostMy m9 pro is finally becoming usable with this new kk ROM!
All previous jb ROMS where slow and unstable.
Looking forward to future improvements and optimisations!
THANK YOU
nfs
Originally posted by rrileypm View PostYes, but I also add nfs.ko.
Code:$ su - root@rk3188:/ # id uid=0(root) gid=0(root) context=u:r:init:s0 root@rk3188:/ # lsmod rk29_ipp 9957 1 - Live 0x00000000 (C) mali 152580 50 - Live 0x00000000 ump 30472 23 mali, Live 0x00000000 rk30xxnand_ko 162075 0 - Live 0x00000000 root@rk3188:/ # insmod /system/lib/modules/nfs.ko insmod: init_module '/system/lib/modules/nfs.ko' failed (No such file or directory) root@rk3188:/ # ls -al /system/lib/modules/nfs.ko -rwxr-xr-x root root 357553 2014-01-05 00:12 nfs.ko
Originally posted by rrileypm View PostI included cifs.ko in the ROM, but these modules have not been tested with KitKat. You guys are doing that. It may be that we need to obtain a new set of ko modules, or find out if we need to do something other than insmod them in the boot.img to get them working in KitKat.
Have you tried using CifsManager to mount the nfs drive?
'Simulate secondary display' option - DON'T ACTIVATE
I don't know how I did it, but this is how it went;
If you activate 'Simulate Secondary Display' you will boot loop your device. So DON'T ACTIVATE ON ANY KIT KAT device for now!
But I still did...
After a lot of bootloops and resets, I was left with the image you see in the attachment.
Only way to get out of this mode with bootloops is with safe mode: which it done with the (missing) menu key :P
I read some post about the annoying power button behavior;
It seems a protection methode, press twice to unlock after long inactiveness. It's gone when just using the device.
Originally posted by netRAT View Postbtw, has anyone successfully switched to ART?
When attempting on my tab it defaults back to dalvik after reboot.
Cheers.
I was actually all set to respond to you, "yes, I'm on ART..." I did change it to ART. My tablet rebuilds the cahche every time I power it on, for 76 apps, which is something my Nexus5 does on ART too, but only for two apps. It takes about 8mins and is a bit annoying, but i just turn the tablet on a few minutes beofre I need it. But then it occurred to me, I just assumed this was a bug and it was compiling the apps for ART every time I power on, but I've never actually chekced the runtime since I changed it. Maybe it's rebuilding the dalvik cache? I don't think so, i'm pretty sure it's ART, it certainly seems faster and smoother when opening apps.
The tablet is turned off at the moment, and I'm not waiting ages for it to boot up, but I'll check next time I have it turned on and let you know
Originally posted by the5th2000 View PostAre you using xposed framework? That changes the runtime back to dalvik.
Hope the dev is able to make it compatible soon. Left with the choice I'm inclined to stick with xposed for now. Tradeoff price is too high...
Cheers.
HDMI output problem
Has anyone faced on that ROM with problem to output signal from tablet to external monitor via HDMI cable?
I've just tried. First there was problem to get signal on the screen (I had to check and uncheck "Turn on HDMI" a several times in a raw otherwise I got "no signal" on external monitor). Second when I finally got android desktop screen on monitor it looked very bad: seemed scaled to 1920x1080 from some smaller resolution and with red and green horizonal lines. Choosing different resolutions and frequencies changed nothing (see attachment).
update: for completeness I have to mention that with same hardware (tablet, monitor and HDMI cable) I had no such problem on Pipo stock ROM.Last edited by knawnd; 17 January 2014, 09:36.
There are currently 1410 users online. 1 members and 1409 guests.
