Enviado desde mi M9pro mediante Tapatalk
Pipo M9 Pro RileyROM 2.5.2 KitKat
usb coneection keeps disconnecting and reconnoecting after trying to flash
I tried to flash the riley rom on my Pipo max-M9. I installed the drivers and the flash tool recognized the tablet. I followed the instructions but the flash failed . Since then the tablets USB connection keeps keeps connecting and disconnecting while plugged in. I can't get it to restsrt the flash process as it does not stay connected for more than about 18 seconds.Any ideas?
Originally posted by rdufraine View PostI tried to flash the riley rom on my Pipo max-M9. I installed the drivers and the flash tool recognized the tablet. I followed the instructions but the flash failed . Since then the tablets USB connection keeps keeps connecting and disconnecting while plugged in. I can't get it to restsrt the flash process as it does not stay connected for more than about 18 seconds.Any ideas?
2: This is KitKat rom and you must tick LOADER in Flashtool because KitKat uses different bootloader.
3: Use the original USB cable (the connection plug is longer than normal)
You have softbrick now,do you guys read ?
It's explained to eternity!!!
I know it's confusing. M stands for Max on the whole M series. The newer versions have Pro in the name. The ROMs aren't interchangeable.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by feanor91 View PostIf I remember well, this is the rom I flashed, I have a "max M9 pro" but "max M9 Pro" = "M9 Pro" and on pipo web site there is no "Max M9 pro" but 2 type M9 and M9 Pro, or did I missed something?
Do this with a Samsung device and you can trow it away.
Never use firmware not intended for your device,it's a GOLDEN rule.
In OP post it's clearly told its For M9 Pro.
Some people are hard headed!!!
Originally posted by rrileypm View PostI know it's confusing. M stands for Max on the whole M series. The newer versions have Pro in the name. The ROMs aren't interchangeable.
M9 pro = Max M9 Pro right?
So we are in therad for M9 Pro si this is the good thread for max no?
There is 2 Pipo m9 type:
M9 Pro (AKA Max M9 Pro)
M9 (without pro = older model)
Don't you get it ???
Originally posted by ludoke View PostOk ,Ok but you can't use roms intented for the M9 Pro on the MAX M9.
If you had readed before,you wouldend be in trouble now.
Originally posted by feanor91 View PostYes, this is totaly true, and I mus say I have some difficulties when trying to choose a rom figuring out the Max on M9, but now, it is more clear, thnaks to you.
All you find there is suitable for the Max M9.
There are currently 1419 users online. 1 members and 1418 guests.
