Do you have cwm works on this rom?
Pipo M9 Pro RileyROM 2.5.2 KitKat
Originally posted by ledadu View Postwhen CWM start, they are many error on misc path... and all partition are inaccessible.
Originally posted by Billcnz View PostRecovery is not working on KitKat customs ROMs yet as they changed the partition layout and we don't have a fully compatible CWM yet
and here: http://www.freaktab.com/showthread.p...rash-on-M8-Pro
The gapps Contacts.apk app doesnt seem to be installed? Well, it is present in /system/priv-app/ but doesnt seem to be actually running.
The icon missing is the icon labelled "People", which loads up the address book, but no such icon with Rileyrom2.5.2?
update:
Saw post#64 on this thread and installed a defroster. Sure enough it was frozen. Now that it's unfrozen I'm trying to figure out why it wont sync my addressbook. gmail account is all set up properly. The option "Contacts" is missing in Settings->Accounts/Google->(my account).Last edited by shimbob; 23 January 2014, 00:56.
Originally posted by shimbob View PostThe gapps Contacts.apk app doesnt seem to be installed? Well, it is present in /system/priv-app/ but doesnt seem to be actually running.
update:
Ok, Contacts now sync.
Here's what I did in addition to unfreezing Contacts.apk:
Grab the latest gapps from CyanogenMod, for CM11. Here.
Open the zip file, extract the file system/app/GoogleContactsSyncAdapter.apk
Have the tablet plugged in, adb debugging on, push the file to the tablet:
Code:adb root adb remount adb push GoogleContactsSyncAdapter.apk /system/app/
Originally posted by knawnd View PostCode:root@rk3188:/ # insmod /system/lib/modules/nfs.ko insmod: init_module '/system/lib/modules/nfs.ko' failed (No such file or directory)
Code:root@rk3188:/system/lib/modules # insmod nfs.ko insmod: init_module 'nfs.ko' failed (No such file or directory) root@rk3188:/system/lib/modules # insmod sunrpc.ko root@rk3188:/system/lib/modules # insmod lockd.ko root@rk3188:/system/lib/modules # insmod auth_rpcgss.ko root@rk3188:/system/lib/modules # insmod nfs.ko ^C^C^C^C^C^C^C^C^C
Code:root@rk3188:/ # lsmod nfs 341669 1 - Loading 0x00000000 auth_rpcgss 34064 1 nfs, Live 0x00000000 lockd 67104 1 nfs, Live 0x00000000 sunrpc 174640 4 nfs,auth_rpcgss,lockd, Live 0x00000000 rk29_ipp 9957 1 - Live 0x00000000 (C) mali 152580 15 - Live 0x00000000 ump 30472 11 mali, Live 0x00000000 rk30xxnand_ko 162075 0 - Live 0x00000000
Randy, where did this nfs.ko come from?
[*] normally on a Linux machine you should use modprobe instead of insmod and it will take care of dependencies, but modprobe is currently broken in this rom.
Honestly, I can't remember where I got this module...I've used several different sources.
If you find one that works, I can change it out.
Also, if you can tell me what order to make the insmod commands or do any changes in the boot.img, I can on my end.
I really haven't tested this much since I started implementing it at the request of users. On 4.2.2 ROM's, I never heard any complaints. It seems that KitKat is more picky.Randy
Originally posted by shimbob View PostThe reason it's failing is because the nfs.ko module has some dependencies[*]. The auth_rpcgss, lockd, and sunrpc modules must be loaded first. However, once you load these modules and then try to load the nfs module, it's hanging for some reason:
Sound problems in some games
Hello
I have installed this rom yesterday in the hope to solve Bluetooth AD2P problem from Android 4.2.2 that conduct to have micro cut sound when looking a video or listen music.
This goal is reach and all the rom works flawlessly, goo and smooth.
Meanwhile, now, I have sound from some games (Real racing, Galaxie On Fire 2 so far) totally distorded, it is like pad have not enough processor power to run the game.
The game is fluid and I can play with it perfectly except sound is crackling and distordef. In Galaxie on fire, for example, the voice islike you listen on a disk than turn slowly than it does.
This 2 games are free, so is someone can try and report please?
And is anyone have an idea of what to do?
I try several other games that works fine including NOVA 3 Modern Combat 4, ARMA II, Clear and Breach, Flash Out 3D Riptide 2 and so on...
EDIT:
Just to precise, I have my phone under KitKat too and no problem with these games. It seems something really related to something in ROM.Last edited by feanor91; 24 January 2014, 09:39.
I really haven't tested this much since I started implementing it at the request of users. On 4.2.2 ROM's, I never heard any complaints. It seems that KitKat is more picky.[/QUOTE]
Mailed Anna at PIPO. This is her reply.
Dear Friend,Good day.Our technicians told me the 4.4 firmware will be released next month after Chinese Spring Festival.Best regards,AnnaPiPo Technology Co,.Ltd(digisino group)金森数码产品(深圳)有限公司
website: http://www.pipo.com.cn
Email: [email protected]
Skype: Anna_pipo
There are currently 2197 users online. 0 members and 2197 guests.
