Pipo M9 Pro RileyROM 2.5.2 KitKat
Guest
Hi
Flashed this ROM and it is great so far!
Overall experience is great.
I have come to a Problem. I wanted to try out the " ro.rk.systembar.tabletUI" true option, but nothing changed except that the volume buttons dissapered!
Changing it back to false does nothing also and yes I did a reboot every time after a change.
Any ideas?
Thanks a lot
Gesendet von meinem M9pro mit Tapatalk
Any ideas?
Thanks a lot
Gesendet von meinem M9pro mit TapatalkRandy
Guest
Thanks for the reply. There are no doubled entries in there.
Do You know an app or tweak to have volume control without going into settings?
Don't want to flash again if Not really needed. Wanted to wait for your next KitKat Rom when pipo staff is back...
Thx for your great work and support
Never Mind, found some in the playstore. thxLast edited by Guest; 29 January 2014, 13:53.
Re: Pipo M9 Pro RileyROM 2.5.2 KitKat
Originally posted by rdufraine View PostI tried to flash the riley rom on my Pipo max-M9. I installed the drivers and the flash tool recognized the tablet. I followed the instructions but the flash failed . Since then the tablets USB connection keeps keeps connecting and disconnecting while plugged in. I can't get it to restsrt the flash process as it does not stay connected for more than about 18 seconds.Any ideas?
Enviado desde mi C2 Platinum mediante Tapatalk
If you installed this ROM on your M9, you have bricked your tablet. The ROM automatically flashed the Loader.bin for the KitKat ROM...which isn't compatible with your M9 Tablet. In order to re-flash a Jellybean ROM back to your M9 (Max) you will need to erase NAND by switching to Mask Mode.
Read Post #2 on this thread for details on how to unbrick your tablet:
http://www.freaktab.com/showthread.p...G-A-KITKAT-ROM!!!!!Randy
Guest
@rrileypm: Hi, did you see this post on making multiuser work on our devices? maybe you can make use of it if you want in the next version or so: http://www.arctablet.com/blog/forum/...k3188-4-4-2-1/
thanks a lot
tullm
Yes, I saw it.
Very interesting. I'll have to play around with it.Randy
There are limits to my magic...hahaha.
I will take a look at that too
Sent from my M7ProRandy
There are currently 5992 users online. 0 members and 5992 guests.
