Sent from my U8 using Tapatalk
Pipo M9 Pro RileyROM 2.5.2 KitKat
Which ROM are you flashing from?
Sent from my U8 using TapatalkRandy
IT WORKED!!!
It is a very nice rom, thanks riley, but the only thing is again the deepsleep, i charged it @23PM this to 100%, came out bed, pickup up @06 and it drained tot 53% (i did only let wifi on, data mobile internet OFF!)
Any suggestions please?
tnx
Originally posted by ledadu View Posthi,
i'v try to reboot in recovery whith tool reboot and touch reboot in recovery but now can't reboot normaly..
i reboot only on the recovery.
what can i do?
A lot of people (including me) have made that mistake.
Usually it's mistaking the M9 Max for the M9 Pro. This 2.5.2 ROM (or any other M9 Pro ROM) will not work with the M9 Max.
Cheers
Cheers
how to reput the m9 pro in Download flash mode? when i'm stuck in recovery.
what can i do?
how to quit the recovery to flash mode!!Last edited by ledadu; 22 January 2014, 11:23.
widgets?
Hi
Flashed and all good love this rom and super fast................
But can't see any widgets? Only see apps, have ticked enable widgets in settings.
All apps restored via titanium but no widgets available and no android settings widget either.
Any ideas as they where fine with riley 2.1?
Cheers
Paul
can't show any partition in recovery
Originally posted by ledadu View Posthow to reput the m9 pro in Download flash mode? when i'm stuck in recovery.
still blocked in recovery
Ledadu,
Reset and let off your tablet.
Connect your tablet USB to your PC (USB 2.0) with the genuine cable of your tablet.
Open flash tool and hold ESC / Reset and Power (all 3 together) and when you see found RKandroid loader... release slowly ESC and Reset and Power.
Erase NAND
Flash ROM
I let you the link to my thread in french with the tuto
Originally posted by ledadu View Postcan't mount or format any partition, maybe the recovery don't see any...
Basically, KitKat has broken the CWM Recovery for Rockchip. Don't ever try installing CWM until a version that fully supports KitKat on Rockchip has been released.
Originally posted by DarthJabba View PostConnect the USB cable, start the Batch Tool, hold down power and volume+ for about one minute or more, then release the power button while still holding down the volume+ button. The Batch Tool should be able to find the tablet then. You might need to try this a few times.
What I do is hold down ESC button and then press RESET button on back. When recovery appears, release ESC button.
1. Start tool and select image to flash.
2. Hold down back button and connect USB.
3. Continue holding back button and press power repeatedly until drivers load. Stop pressing power when you see the drivers
I've also started having the same problem with the reboot app. There must be something with KitKat that prevents the reboot app from working...or CWM doesn't save the misc.img correctly to reboot the system.
That's a priority for me to address with the other developers.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Re: Pipo M9 Pro RileyROM 2.5.2 KitKat
Originally posted by ledadu View PostThe rom work but i wana try recovery, and, i'm stuck into.. :/
Sent from my m6pro running Riley ROM 1.7 KitKat
There are currently 1826 users online. 1 members and 1825 guests.
