Thanks to lewy20041!
This rom is for CX-921 / PowerPro without bluetooth!!
I adapted and cooked his ROM to fit my personal needs.
This rom is a pureXBMC based android media center with Dolby/DTS passthrough,
playing every video file without any problems!
AnTuTu Score: 21072 ( CPU 1800, GPU 600, DDR 800 )
I did some changes for the CX-921/EXOON POWER PRO, rkxx-remotectl.kl, new design and some tweaks and modifications, some changes to resolution switch under advanced settings (will show resolution for reboot) and added new kernels.
Thanks to Finless for 1080p Kenel.
Thanks to phjanderson for Rockship Patchomatic Suite!
Thanks to stafstrom for patching libs.
Thanks to rrileypm who helped me starting linux and gave me a lot of tipps!
Thanks to MINIX and LEWY for XBMC-MINIX_BETA2_SG3.
Thanks to FREAKTAB.com!
I hope you'll like this ROM - walter77.
This is inside:
Real 1080p kernel as default
Real 720p kernel, switch by only a click in "pureXBMC" advanced settings
xbmc (XBMC-MINIX_BETA2_SG3) internal player with dts/dolby/analog sound support,
preinstalled after first start (wait 2 minutes after first boot)
pureXBMC settings section under android settings
-Performance settings ( clock down kernel if you get problems )
-Super User
-Terminal
-Advanced settings
- update
- reboot recovery
- reboot bootloader
- swich resolution (use it if you don't need 1080p, it will swich to 720p "better for gameing") with indication of resolution
-pached libmedia.so for Dolby/DTS
-new graphics
-system bar hidden
-rooted
-remote, mouse, gamepad support
-better mappings for xbox wirless gamepad (supports more games)
-init.d support
-gameloft fix
-new power off background and icons
-nfs support with automount on startap scripts (check /system/etc/init.d folder)
-build.prop tweaks
-cwm recovery
-real 1080p kernel (resolution can be changed under android settings)
-all apps deleted (only settings, store, browser, download provider and Root Explorer are left)
-changed bootanimation to pureXBMC
-latest XBMC-MINIX_BETA2_SG3
changed icons and splash screen to stock xbmc
#Install
-unpack arhive (anywhere)
-start \RKBatchTool\RKBatchTool.exe
-put device into flash mode (press and hold reset button, conect otg to pc and box)[if you already using Custom ROM, try to reboot to bootloader]
-install proper drivers when windows ask from \Drivers\ folder
-when you wil see number 1 in green box select "..." button in right top corner of RKBatchTool
-navigate to pureXBMC_V1-1-1_CX-921.img
-press restore button in RKBatchTool
#After install
#Things to do after you install firmware.
first bootup will be slower then the next one (android is setting up)
xbmc installs right after first boot, wait at least two minutes to let the box set up
If you want HDMI Audio Passthrough, activate RK29_RK1000 PASSTHROUGH under Android Settings/Device/Sound/Sound Device Manager. Start pureXBMC got to System/Settings/System/Audio output and just set Audio Output to Optical/Coax.
Your Audio will be delayed if you choose audio passthrough.
You can correct it by playing a movie and change the audio options for the movie.
Change Audio offset Ahead by: 0.200s and set it as default for all videos.
Download:
http://www.media-base.net/roms/pureX...-1c_CX-921.rar
Update 11-01-2013!
CPU 1800, GPU 600, DDR 720 - New Kernel from Geekbuying.com
(CX-921 SKU165055&165066&164073&164467)
Thanks to Bob for patching 1080p version!!
Remote should work now on more devices, led should turn off on sleep.
Please test and report back!
Use it at your own risk!
