NEW!! pureXBMC "new firmware for CX-921 / EXOON Power Pro"
    Hi there Walter, rom runs great but hdmi audio passthrough does not work on my cx921.
    I just get an audio ticking which is the best way to describe it.
    Also power light does not go out on standby or power off, other than that everything works fine here, just thought I'd give you some feedback.
      Originally posted by mfloppy View Post
      Looks just like that... Would I have to go back to stock then send system kenel ?
      Does your device have bluetooth?
      Seems that CX-921 with bluetooth have the same firmware as T-R42.
      Quite strange with different hardware, no info about revision, only inside the box.
      I need the full working stockrom from your box with working remote.
      I will ask Bob to patch your stock kernel to 1080p and if he will patch it, i will build a pureXBMC for your device.
      In the meantime you can try to flash only T-R42 kernel from wasser rom or K-R42 kernel on top of pureXBMC just to test, if your remote will work with any of those kernel.
      For working pureXBMC with resolution switch i need working overclocked 720p/1080p kernel.
      Something like CPU 1800, GPU 600 and RAM 720 would be perfect.
      Gesendet von meinem iPad mit Tapatalk HD
      Donations are welcome and will be shared with other devs:
      DONATIONS
      CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
        Thanks for your feedback!
        So what are your android audio settings and what are your XBMC audio settings?
        Is your remote working?
        DONATIONS
          I know about the powerlight, but that doesn't worked on your stock rom too, right.
          DONATIONS
            My audio in android is set to RK29_RK1000 PASSTHROUGH, in xbmc I have audio set to optical/coaxial even though I only have hdmi on the box.
            I get the Dolby light on the amp when playing a Dolby stream but just a clicking noise, the amp and hdmi works fine with a Matricom mx2 so I know amp and hdmi cable are fine.
            On stock kernel the power light does go out on standby and shutdown so there must be a setting in the kernel somewhere I would have thought.
              Can you send me that kernel? It seems that my box was one of the first hardware revisions and they changed hardware later. Ihave the same settings and it works perfect.
              Have you tried different android sound settings, just to reset cache and switched back to passthrough?
              DONATIONS
                No it doesn't have bluetooth
                  No, no known issue. Just did some research.
                  Seems that there is a second revision of CX-921 with different IR chip.
                  The driver for IR is placed in kernel as i know. So can you send me your stock rom (update.img) or system.img and kernel.img?
                  Does your device and remote look like this?
                  this is my stock image with stock control http://www.mediafire.com/download/rx...3%26164467.rar
                    IR Remote doesn't work
                    Thanks for this Flash Walter77
                    but, i have the same Problem, my IR Remote doesn't work. My Android Box looks same without Bluetooth.
                    what can i do for working please.
                    Thank you
                    oetzi
                      Last post I meant that the link is the update image of my box with working ir... Hope this works
                        I will look at it later. Just a short question. Where have you bought this box and where is the update img from?
                        Ah, i see, it's the latest from geekbuying.com. right?
                        DONATIONS
                          Yes i bought the Box here:
                            Updated Kernel! New link on first post.
                            Added new Kernel from Geekbuying.com!
                            (CX-921 SKU165055&165066&164073&164467)
                            Patched to
                            CPU 1800, GPU 600, DDR 720
                            Thanks to Bob for patching 1080p version!!
                            Stock remote should work now on more devices, led should turn off on sleep now.
                            Box is even faster now!
                            Please test and report back!
                            DONATIONS
                              Patched to
                              Great! Remote, Wireless, HDMI Passtrough its working!
                              thanks for all
                                Patched to
                                I keep getting boot loop or it will run for a lil bit then rebook and stay on the penguins and stay stuck there.
