Paragon mounter will show the location of the drive. Use root explorer to change the permissions of the folders (r,w,x) to that location. The drive will now be accessible. Still will not show it is mounted on cx-921 storage settings.
NEW!! pureXBMC "new firmware for CX-921 / EXOON Power Pro"
I am new here.
I have only experience in flashing roms für smart phones. The first thing what I do with my new CX-921 is to flash your nice rom (1.1.1c). After it is finished the box restarts and I see four linux tux'es. I'm wait, but the box does nothing. What's wrong ?
thx
EDIT: Now I see you have diffenent versions of your rom, for different devices. My device is this one. I think I shoud try an other version of your romLast edited by Serioussnape; 08 March 2014, 01:22.
Originally posted by Serioussnape View PostHi,
I am new here.
thx
Gesendet von meinem iPad mit Tapatalk HDDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
I am new here.
thx
DONATIONS
Thank you for your help! :-)
But it's the same problem :/
Now I must find an other rom that works with this cheap box.
EDIT: The difference about your box and is only the storage ?! Your box have 16G and my 8G storage.Last edited by Serioussnape; 08 March 2014, 09:31.
Alternatively you can try Wassers version for K R42 and try different kernels.
Your stock remote will not work but the rest should. Installation takes between 5 and ten minutes, thats normal. Sometimes there is 5 minutes black at first boot, that's quite normal. Please report back.
Edit: i think the difference is not only 8 to 16 gig but also your box has locked cpu, gpu, ram speeds. There is a lot to find here at freaktab. I think the most new boxes except minix using the cheaper rk3188t chipset.
Gesendet von meinem iPad mit Tapatalk HDLast edited by walter77; 08 March 2014, 11:06.Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by Serioussnape View PostThank you very much.
This Rom works very well. Only the remote doesn't work, like you say before. In addition the LAN Controller doesn't work, but the WLAN works.
Is the CPU/GPU/RAM now unlocked ?
If you would like to test pureXBMC you can flash it and after flash is completed, just flash a working kernel on top.
Sent from my iPhone using TapatalkDonations are welcome and will be shared with other devs:
DONATIONS
just installed firmware, glitchy
hey guys i have looked everywhere possible for an answer on this and yet to find anything remotely close to my issue.. i installed the firmware on my cx921 box. The good box not the "t" version. Anyway everything runs great Except on my tv screen i keep getting single flash lines across my tv.. There will be a "flicker of a white line" every few seconds is different place. i have a samsung 1080p tv and have tried even switching to the 720p kernel and still the same thing.. Strangley enough when i switch to even lower than 720p such as 480 there are no more glitchy lines that flash .. Any ideas? im about to chuck this box out my front window..."not really" oh also i reinstalled firmware and still same thing.. oh yea also the screen keeps "resetting" it will go black for a second and come back on
Originally posted by kbar15000 View Posthey guys i have looked everywhere possible for an answer on this and yet to find anything remotely close to my issue.. i installed the firmware on my cx921 box. The good box not the "t" version. Anyway everything runs great Except on my tv screen i keep getting single flash lines across my tv.. There will be a "flicker of a white line" every few seconds is different place. i have a samsung 1080p tv and have tried even switching to the 720p kernel and still the same thing.. Strangley enough when i switch to even lower than 720p such as 480 there are no more glitchy lines that flash .. Any ideas? im about to chuck this box out my front window..."not really" oh also i reinstalled firmware and still same thing.. oh yea also the screen keeps "resetting" it will go black for a second and come back onDonations are welcome and will be shared with other devs:
DONATIONS
There are currently 1456 users online. 1 members and 1455 guests.
