NEW!! pureXBMC "new firmware for CX-921 / EXOON Power Pro"
    Thanks once again Walter
    I guess what I am trying to say IS THANKS - can not say it loud enough.
    The reboot thing was just me nit picking, I am just so used to seeing the green reboot apk program being pre-installed. Anyway, as my technical knowledge of hex is limited (very) - If you do get around to doing a 6 parameter file then I will start looking for the donate button
    Leolas could do it if I ask him nicely - but if it's not much effort then more please sir more as Oliver would say - begging and groveling as nicely as I can
    Thanks Thanks Thanks Thanks Thanks Thanks
    Thank you
      Does anyone use the advanced section under android settings?
      Does anyone use the switch to 720p kernel option?
      Gesendet von meinem iPad mit Tapatalk HD
      Donations are welcome and will be shared with other devs:
      DONATIONS
      CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
        Yes (in recent hours to enter bootloader) and No.
        I've also checked my ethernet problem, and Wasser's kernels work fine in this respect (I haven't tried the passthrough yet though), there is, however, a significant drop in performance.
        with your "c" ROM i get Antutu score 18330
        with "c" and wasser's kernels:
        kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h, 1800p@60Hz> 13684
        kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h, 1800p@24Hz> 14455
        kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h, 1800p@60Hz> 14108
        kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h, 1800p@24Hz> 13970
        with your "d" ROM i get Antutu score 17352
        with "d" and wasser's kernels:
        kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h, 1800p@60Hz> 13914
        kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h, 1800p@24Hz> 13778
        kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h, 1800p@60Hz> 13740
        kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h, 1800p@24Hz> 14157
        So there is no significant difference between the Wasser's kernels, but they are significantly worse performing than yours. I'll report back when I check the passthrough (and mainly the AAC>AC3 decoding).
          Really slow performance, can't explain that. I don't know the difference between new and old revision, but i think it's lan and wifi chipset ;-)
          My kernel is just a 1080p patched and overclocked stock kernel.
          Do you have a working 1080p stock kernel for your device?
          DONATIONS
            Does your wifi work with my pureXBMC kernel?
            DONATIONS
              WiFi works with your pureXBMC ROM, but I believe works better with Wasser's kernels (I can see more networks around me, but that does not matter, mi router is 40cm from the box).
              I don't have any original kernels anymore - the one that was there from the box is gone (I didn't manage to back it up, and I thought I had a factory FW from the net, but it turned out to be not working) and besides it wa also just 720p upscale - if I can believe XBMC.
              I've just tested your "d" with one of the Wasser's kernels (I guess it was kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h, 1800p@24Hz) and the passthrough works just fine, but the movie plays SLOWLY - the video is slower and the audio too, so that it makes voices different
              ...and now I've tested it @60Hz and it seems to be just fine...
              I think I'll stick to it for now, I'll try to get the original FW from somewhere, just in case...
                Have you tried wassers 1.2.4 rom for k-r42 with this kernel on your box?
                AnTuTu Score?
                DONATIONS
                  I've tried it just now, score 12543. That means your adjustments really improve it
                    hm, I just noticed one more weird thing... although your pureXBMC ROM does produce AC3 (Dolby Digital 3/2.1) signal from 5.1 AAC sound track (as recognised by my receiver), in my case it's actually only a 2.1 sound (the center and surround speakers are silent). I wonder if it's just me or a more general issue...
                      I only have 5.1 AC3/DTS movies, so i never tested a 5.1 AAC file.
                      This seems to be a XBMC related issue, have to look for this issue in minix forum.
                      Have you tried different audio settings in xbmc, 5.1 Speaker configuration for example?
                      Is your receiver AAC capable?
                      DONATIONS
                        no receiver is AAC capable, as far as I know... AAC is basically a compressed AC3 sound track, so the player should be able to decompress it (just like the video track) and send it further as AC3 sound. And yes, it seems to by mainly XBMC thing, your ROM is however the one and only that has been able to produce AC3 sound from a non-AC3 (AAC in this case) source... I'm downloading some sound test videos, so I'll check the whole thing in a comprehensive way in a while.
                          Ok this is weird
                          So I got around at last to doing a comparison of your 8GB parameter file - and it is identical to mine - but when I use that parameter file on my 2 boxes with the - Ugoos_UT1_RileyFinlessROM_v1.0a - roms with either RK3188Loader(L)_V1.20.bin or 1.24 then both boxes just hang during boot. If I switch it out for the 4gb parameter file - then both boxes boot - I think I am going nuts.
                          And like I said this used to work on my old CX-921 - I swear the more I know about computers the more screwy they act.
                            Having issues with output
                            Hi
                            I don't know what's the problem, but the ROM sometimes loses the output via HDMI. It goes dark for a second or two and then it just keeps on playing the video, running an app.
                            I am using USB power, because the store sent the wrong power adapter, and when I used an old USB cable to AC with an USB power brick the unit crashed continuously.
                            Any ideas?
                            PS: In all other news, the ROM is working perfectly for me. Awesome work!
                              Originally posted by nielsv View Post
                              Hi
                              Any ideas?
                              So you never had this problem before on any other rom?
                              DONATIONS
                                I have the same blinking problem
                                Forget this post - but the blinking problem can be fixed by changing the screen res.
