NEW!! pureXBMC "new firmware for CX-921 / EXOON Power Pro"
Originally posted by pixelindream View PostDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by walter77 View PostSeems to be no T-Kernel!! But different hardware then my CX-921. There are 3 different revisions on the market as i know. Should your device have bluetooth? Can you please check wifi with kernel 3 and 2?
Kernel 3, Wifi Works
Kernel 2, Wifi does Not work
Kernel 3 and 2 and your Rom ,ethernet does not work
You can try UT1: http://www.freaktab.com/showthread.p...asser-firmware
or http://www.freaktab.com/showthread.p...asser-firmware
K-R42 old should work with wifi, but perhaps ethernet will work, but you can try new Version two and you can try T-R42 new and old version kernels two from T-R42 thread.Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by walter77 View PostSo your device have RTL8188 wifi chip but another ethernet chip. Kernel 3 is non overclocked stock kernel from original CX-921. Kernel 2 is Stock AP6210 kernel.
Originally posted by pixelindream View Posthi.. i am new to all that stuff.. Recentley i bought a android box named Egreat U8. Then i flashed your cutsom rom (pureXBMC_V1-1-1d_CX-921). it seems to be ok but my screen blinking constantly even when installing. I can see anly for e few seconds and then black screen, and it goes on en on..i dont know what to do now any suggestion please? ( flashed with 'restore' option and tried many times)
Originally posted by adam-cx921 View PostHi Walter,
Is it possible to provide your firmware and I'll try flash it with wasser's flash utility and the kernel version that I'm currently using.
Does this solution sound viable to you?
Much appreciatedDonations are welcome and will be shared with other devs:
DONATIONS
СХ 921 Без блютуз!Привет Walter!Прошил свой сх 921,но т
[QUOTE = walter77; 128547] . Эта прошивка основана на MINIX X7 justXBMC 1.1.1 на lewy20041
! Благодаря lewy20041
! Этот ром для CX-921 / PowerPro без Bluetooth я приспособился и приготовленные его диск, чтобы соответствовать моим личным потребностям. Это ром является основе pureXBMC андроид медиа-центр с Dolby / DTS транзит, играя каждый видеофайл без проблем! AnTuTu Оценка: 21072 (CPU 1800, GPU 600, DDR 800) , я сделал некоторые изменения для CX-921/EXOON Power Pro , rkxx-remotectl.kl, новый дизайн и некоторые хитрости и модификации, некоторые изменения к резолюции переключателя под расширенные настройки (покажет разрешение для перезагрузки) и добавлены новые ядра. Благодаря Finless для 1080p Кенель. Благодаря phjanderson для Rockship Patchomatic Suite! . Благодаря stafstrom для исправления, освобождает ! Благодаря rrileypm который помог мне начать Linux и дал мне много Tipps . Благодаря MINIX и Леви для XBMC-MINIX_BETA2_SG3 ! Благодаря FREAKTAB.com Надеюсь вам понравится эта ROM - walter77. Это внутри: Настоящее ядро 1080p как по умолчанию Real ядра 720p, переключатель лишь одним щелчком в "pureXBMC" расширенные настройки XBMC (XBMC-MINIX_BETA2_SG3) внутреннего игрока с поддержкой звука DTS / Dolby / аналоговый, предустановленной после первого запуска (подождите 2 минуты после первой загрузке) настройки pureXBMC раздел под андроид настройки параметров-Performance (часы вниз ядра, если у вас возникли проблемы) -Super User -Терминал -Расширенные настройки
- обновление
- Восстановление перезагрузка
- перезагрузка загрузчик
- Swich разрешение (использовать его, если вам не нужно 1080p, он будет Swich до 720p "лучше для gameing") с указанием резолюции
-pached libmedia.so для Dolby / DTS
-новый графический
штрих-система скрыта
укоренившихся
-пульт, мышь, геймпада поддержки
-лучше отображений для Xbox Wirless геймпад ( поддерживает больше игр)
-init.d поддержка
-Gameloft исправить
новый выключение фона и иконки
-NFS поддержки с автомонтирования на скриптах startap (проверьте / система / и т.д. / папки init.d)
-build.prop твики
-CWM восстановления
реального 1080p Ядро (резолюция может быть изменена в соответствии с андроид настройках)
-все приложения, удаленные (только настройки, магазин, браузер, скачать поставщик и Root Explorer являются слева)
-изменены bootanimation чтобы pureXBMC
-последнее XBMC-MINIX_BETA2_SG3
изменилось значки и заставку с фондового XBMC # Установка -распаковать Архив (в любом месте) -старт \ RKBatchTool \ RKBatchTool.exe -положить устройство в режим вспышки (нажмите и удерживайте кнопку сброса, Conect OTG для подключения к ПК и коробке) [если вы уже используете пользовательского ROM, попробуйте перезагрузить, чтобы загрузчик] установить соответствующие драйверы, когда окна просить у \ Drivers \ папка -когда вы Виль см. номер 1 в зеленом поле выберите кнопку "..." в правом верхнем углу RKBatchTool -перейдите к pureXBMC_V1-1-1_CX-921.img -пресс кнопку восстановления в установить # Развлечения после установки прошивки. первой загрузки будет более медленным, чем следующему (Android является создание) XBMC устанавливает сразу после первой загрузки, подождать не менее двух минут, чтобы окно настройки Если вы хотите HDMI Audio транзит, активируйте RK29_RK1000 PassThrough под Настройки Android / Устройство / Звук / Sound Device Manager. Начать pureXBMC добрались до System / Settings / System / аудио выход и просто установить аудиовыход для оптического / Coax. Ваше Аудио будет отложено, если вы выбираете аудио транзит. Вы можете исправить это, играя в кино и изменить аудио вариантов фильма. Изменить Аудио зачете впереди по: 0.200s и установить его по умолчанию для всех видео.
Скачать:
http://www.media-base.net/roms/pureX...-1c_CX-921.rar
Обновление 11-01-2013! CPU 1800, GPU 600, DDR 720 - нового ядра от Geekbuying.com (CX- 921 SKU165055 & 165066 & 164073 & 164467) Благодаря Бобу за латание 1080p версию!! Дистанционное должны работать теперь на большее количество устройств, во главе следует отключить на сон. Пожалуйста, проверьте и доложить! [/ QUOTE]
СХ 921 Без блютуз!Привет Walter!Прошил свой сх 921,но тв бокс не работает Лан,и моргает экран на 1080р.нормально работает только 720р,в
в чём дело не понимаю,можешь ли ты помочь: Лицо.У же пробовал все прошивки,и даже стоковую!результат ноль!
After many roms and kernel trying, finally everythings is perfect now. I am using your Rom with Wasser Kernel "kernel-1080p-t-r42-new.img".. Wifi, ethernet is working as they should and xbmc playback performance is excellent.. I just wanted to report and thank you of course..
Regards..
Regards..Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by walter77 View PostCool and thanks for the info! Can you send me your working 720p and 1080p kernel. I can build an image for other user with CX-921 T-Chip Box. I don't know which wifi chipset T-R42 new has but will look for that later.
Originally posted by nukeybrown View Postdid is you manage to create image yet as I have the same issue , constant flashing screenDonations are welcome and will be shared with other devs:
DONATIONS
There are currently 4560 users online. 0 members and 4560 guests.
