NEW!! pureXBMC "new firmware for CX-921 / EXOON Power Pro"
    no sounds from apps
    hi..
    its weird.. i can get sound from mxplayer or xbmc but i cannot get from any apps like browser or games etc.. And in android settings > sound when i click on "volumes" i get an error : "unfortunately, setting has stopped".. Tried google for hours but no chance
    Any idea?
      Originally posted by pixelindream View Post
      hi..
      Any idea?
      Yeah i know about, it's corrupt. I deleted to much system stuff ;-)
      Donations are welcome and will be shared with other devs:
      DONATIONS
      CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
        [QUOTE=walter77;174502]
        Just you did say above you were gonna put an image together .
          oops
          Solution is a new rom image then..Right?
            [QUOTE=nukeybrown;174521]
            Can anybody help me with this flashing screen thing?
              [QUOTE=nukeybrown;174557]
              Please try to flash wasser kernels from 1.2.5 roms (UT1, K-R42, T-R42) on top.
              Or you can try d33 t-override kernels flash on top:
              AP6210 / AP6330 / RT8188+VMAC / MK7601 wifi variants v1.02
              DONATIONS
                oops
                Yes, just building a new rom. At the moment it's working for my CX-921a with RTL8188EU wifi and non T-chip. It's an amazing experience with modded XBMC from Flumpster. I build a new kernel from source for this rom, smooth playback is working with stock 1.6 Ghz speed.
                The problem is, that all new CX-921 from 2014 have new chipset i think, with new wifi chip and silly T-chip.
                I will provide some beta-test-build soon.
                DONATIONS
                  I will not put an image together with wassers kernels inside, sorry. I don't know why, but for some reason, some people are a little bit strange here. I'm german two, so that can't be the reason ;-) I asked wasser about hundred times and a lot of things, but nothing happened...
                  But flashing kernels on top is really easy and explained hundred times at many places :-)
                  At this point many thanks to Bob, D33 and Lewy ( and all the people i forgot to mention ) for always answering my questions and helping me, that's fun!!
                  DONATIONS
                    [QUOTE=walter77;174695]
                    dont think its 2014 model as opened it up and board date is 2013
                    still not sure how to just flash the kernel though. if you could message a link of a kernel for testing that would be great.
                    ps think everyone here is doing an amazing job. looks like purexbmc could be very promising if it wasnt for this flashing screen thing
                      [QUOTE=nukeybrown;174722]
                      Please try this kernels:
                      http://www.freak-tab.de/wasser/kerne..._new-1.2.5.zip
                      Extract the kernels in the directory you extract this tool here, set your box to flash mode and select only the kernel you want to flash. Try which kernel works best for you and report back. Stock remote will not work with this kernels from washer.
                      Using RKAndroidTool to flash image by partitions
                      Download RKAndroidTools from here. Unzip it the file and double click RKAndroidTool.exe, you will then see the interface as follows:
                      Power down the Radxa Rock board and connect the Radxa Rock board to the computer and let the board go to loader mode then the program will detect it.
                      There are eight selections to choose from so select the correct row and then select the checkbox to the left of the row to select it. After you must click the column on the right side for the path of the file you want to flash. You can then select one or more files and flash them at once. Finally Click "Run" to flash images to the device (the right most selection shows the log of the progress).
                      If successful the board will disconnect from the tool and boot into the system.
                      DONATIONS
                        [QUOTE=walter77;174728]
                        So do I just select kernel or kernel and system then on system choose your new build version d with wasser kernel?
                          [QUOTE=nukeybrown;174877]
                          If you download pureXBMC from here, there is a tool for installing it inside the package, it's just one big firmware image. This image includes boot, kernel, recovery, sytem and such things. Cause the kernel inlcuded in this firmware does not work with your box, you only have to change the kernel, for example with one from wasser. You can do it with tool tool and the manual i've posted last link. Only select the kernel, deselect any other things like sytem, loader and so on. Set your box to flash mode and press the run button. Now only new kernel will be flashed, device will reboot automatically.
                          If the flashed kernel does not work, try another one. Good luck! And please report back which kernel worked and where you bought your box. Please only try 1080p kernels at this step!!
                          DONATIONS
                            [QUOTE=walter77;174920]
                            my my pc has decided to die on me , so cannot test for the next few days till I get it sorted.
                              I've tried firmware after firmware and still the same , no go. Some of them don't boot , some do with same issue glitch in screen every 3 seconds, tried most if not all of wasser firmware files and same, only 1 that boots up is yours c version. Might just put this box in the trash as the remote pick up on this thing is terrible, can't get more that 10cm away from box or it doesn't work. Bought from geeks buy
                                I had some time at weekend and will upload a testbuild of pureXbmc V2 hopefully tomorrow.
                                New system, new kernel ( and a lot kernel to test ), new look. At this time only for CX921a with RTL8188 wifi and no bluetooth. No T-chip override at the moment, but i hope i will get it done with the help from d33?
                                New IR driver, new HDMI Driver ( hopefully no flickering anymore ), Kernel build with latest Radxa source, Includes mod of Flumpsters Beyond XBMC. It's a working JB 4.2.2 rom with full flash support.
                                DONATIONS
