Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
    If it's just put to sleep it comes back. But if power is cut as cord pulled out of the back or unplugged from the wall everything looses settings. I messed with my x7 I have here too and pulled power many times no problems.
    Could the box itself be bad?
    Sent from my iPhone 5 using Tapatalk
      Re: Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
      maybe the box is bad, but i will suggest flashing it from pc (make idb erase before flashing) and see if it happens again.
      There are 10 types of people in the world: Those who understand binary, and those who don't...
      If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
        Originally posted by daemonium View Post
        First page, post number 4. There you are.
        This dont work, please help !!
        ... TVDroid
        > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
          do you have a mini or a normal x7?
          have you tried to manually disable the "connect to pc", reboot and look if it's still activated?
            Try the one in page 6 , post 107. This works for me great
              Dont see my sig. ? I got a mini. Please change the Posting on the first Page, this fix dont work, but the fix from Page 6 works great!
              Thank you this works great!
              ... TVDroid
                i read this forum through Tapatalk, i can't see the signatures.
                i'll change the link on the first page.
                EDIT: First page changed, now there are the two links, i leave the first one just in case.
                  Minix Neo X7 Android 4.2.2 TV Box 1.8GHz RK3188 Quad Core 2GB RAM, audio passthrough
                  Let me start saying good job with the quikshot v2 best rom that I have tried so far
                  I have installed the quikshot v2 on my device
                  Audio is out of sync when using xbmc I have to use audio offset to adjust
                  In xbmc under system settings In audio output Under passthrough output device
                  I get this error No devices found
                    Make sure you go into settings audio in the box and go to either hdmi pass through or optical pass. I think it may say rockchip spidf or something.
                      Enter Download Mode for Reflash
                      Anyone know hot to enter download mode on this rom?
                      everytime i did the step to enter recovery mode, it always enter in CWM mode...
                        I think you search bootloader mode? To be flashed from PC?
                        leolas
                        sent from my phone.
                        My devices:
                        Gearbest.com)
                          leolas
                          sent from my phone.
                          yes....exactly...
                          everytime i push the reset button and connect it to pc...it goes to CWM mode...
                          can u tell me how to enter the bootloader mode?
                          sorry for my bad english
                            yes....exactly...
                            From terminal emulator if you are root use:
                            su
                            reboot bootloader
                            If you are root you can use petrus reboot.apk.
                            If yo are not root, be sure that your otg usb port is connected to PC, it will be in loader mode for at least 2 minutes.
                            leolas
                            sent from my phone.
                            My devices:
                            Gearbest.com)
                              Jesurun MX Quad Core
                              Hi Guys
                              Can anyone tell me if I can try this ROM on a friend's Jesurun MX device ?
                              Spec seem to be the same and they even look alike.
                              Thanks!
                              Link to the device
                                Hi you guys.
                                I'm new here, and i'm writting this because i recently bought the wonderfull Minix Neo X7, after searching for a custom firmware i reading a lot of reviews from others users, i've installed the Quickshot V2 rom on my box.
                                Let me say, that you guys (Nitro Team) have made a stuning job and a great rom. I'm using it almost 1 week now, but i'm having some problems with it.
                                When i'm the Store (google play store), sometimes the box reboots itself and other it shutdown completly, i need to press the power button on the box to power one again.
                                And this kind of strange symtoms already happen when i'm navigating the web, i'm using the Chrome browser.
                                Someone have already this problems, and how they can be resolve.
                                Another thing, i am anxious to see what you guys will do in next rom (Quick V3)...
                                Thanks.
