Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Originally posted by Flygye View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by Malandro2011 View PostHi Guys
Can anyone tell me if I can try this ROM on a friend's Jesurun MX device ?
Spec seem to be the same and they even look alike.
Thanks!
Link to the device
http://www.dx.com/p/jesurun-mx-quad-...0#.U2mDpHmIrIU
if you want to try, do it at your own risk.There are 10 types of people in the world: Those who understand binary, and those who don't...
Hi guys,
First post here and already it is to ask for some help.
I got a Minix Neo X7 mini this week and I want to install this ROM.
I started the process by Erasing IDB and trying to install the firmware but during the process of installation I got an error saying that the Download of something failed (I can't remember what and I already closed the app so I don't think there's a log where I can see that)
I've tried two methods already:
- The first time I used the cwm method by putting the zip file on the device, rebooting into recovery and then proceed to install. Everything went fine with just 1 thing to note - I can't use the device since it won't boot and just stays still on the sreen with "Minix" written on it and a Android doll. It won't get passed that.
- The second time I tried the method of installing it from the PC. Since I have a Mac I've been using a VM with windows XP.
I installed the drivers and started RKAndroid Tool, the device got recognized and so I proceeded to erase the IDB. Just after that, and since I had no errors erasing the IDB, I clicked on the install button, got a few steps into the process and the I got an error message saying that the download of some component failed.
Since then, I've been unable to make RKAndroid recognize the device, boot into recovery or anything else.
When I disconnect the device and then connect it again I apparently get the computer to detect it since it asks me to which computer I want to connect the device to - OSX or the Windows machine inside the VM (I always choose to connect to the VM) - but still RKA won't detect the device.
Given this, I'm in dire need of your help to get it to work again.
I'm putting the log here in the hope that someone can make sense of it.
I've already tried a few methods that had work for some people on the "normal" X7 and every single time I just can't make anything of it.
Can anyone help me please? How can I get it to work again, even if it's for the stock firmware? None of the tools recognize the minix anymore.
look for a computer with Windows xp, forget about VM at this moment. Look here at freaktab for the short nand pins method and apply it.
Be sure the nand is the same.
EDIT: Found this http://valentijn.sessink.nl/?p=517There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Postwell, since your device is already dead what i'll propose now won't hurt.
Hello!
first than all, thank you for your excellent work.
regretfully, I'm writing because I need a bit of assistance.
I ended up with a boot loop after installing.. but I had issues.
I currently only can enter CWM recovery after pressing the reset button for 2-3 secs after I plug in the power cord of x7-mini; the files for installation are inside the x7-mini but the system somehow can't see them (file too big.. above 300 MB, same as quickshotv2 rom). Fortunately I have a backup,
I managed when it was on stock rom, to
- root the minix
- install cwm
- reboot into recovery
- take a backup of the system as it was before attempting to push via 'adb push'
I copied the files for installing via USB-OTG mount for running from CWM, but the recovery can't see them, but my computer can perfectly see the files (win7 x64, used moborobo to root and install cwm after I had no success with the RKAndroidTool).
via adb push I managed to get cwm-recovery to install the rom via sideload but after rebooting is stuck in boot loop
Any ideas/ways to either:
- complete install of Quickshot
- go back to the backup as it was before... so I can try again.
- maybe do I have to copy files back to PC, fully re-partition the storage mem of the x7-mini, and then try to push via sideload?
I was never able to use the rockchip program though
now.. if there is a way to get it to work with the x7-mini in CWM-recovery, it would be nice to know.
thank you in advance.
Recovery mode
I have run the rkandroid tool on a Xp laptop. Finished process run ok. Now when I connect to the tv I just get recovery mode.. What am I doing wrong how can I fix this problem
its says recovery system v4.2.01
android with red triangle
says reboot system
apply update from adb
apply update from external
update rkimage from external
apply update from cache
wipe date/factory reset
wipe cache partition
recovery system from backupLast edited by Handy77; 24 May 2014, 11:31.
Originally posted by Handy77 View PostI have run the rkandroid tool on a Xp laptop. Finished process run ok. Now when I connect to the tv I just get recovery mode.. What am I doing wrong how can I fix this problem
says reboot system
recovery system from backupThere are 10 types of people in the world: Those who understand binary, and those who don't...
Did what u said now I am trying to get back to official firmware for mini using RIBAtchtool and official firmware x7mini.img. I have the hdmi connect so I can see if it connects to TV. I click restore let it do it's thing when it says success keep it plugged on for 30 minutes still nothing tv says no signal tryed to TVs. After 30 minutes unplug it then it connects to the tv but still in recovery
someone please help get out of this recovery mode
i too tryed this firmware couple times still no success waited ages still nothing unplug then connected to tv recovery mode
tryed again with lower firmware still same outcome and ltest firmware
still waiting left everything on for 30 minutes still blue screen on tv has not changed stuck on no siginal . i will now unplug power connect it again i still return back to recovery mode
here some pictures
please anyone help i just got it yesturdayLast edited by Handy77; 24 May 2014, 19:16.
did you flash any kitkat firmware?There are 10 types of people in the world: Those who understand binary, and those who don't...
There are currently 1762 users online. 1 members and 1761 guests.
