First of all, I will make a patch to go back for the people that flash the f10pro patch.
But in the meantime you can do this :
Reboot to recovery by using the reboot app we provide, yes that app down in the launcher.
make a cwm backup to external sd.
Reboot
Apply the f10 patch using quickflasher app, to do this just copy the patch to the folder /sdcard/quickflasher without uncompressing it, then just open quickflasher select the patch, apply and reboot.
The patch doesn't affect to kernel.
hope this helps.
