Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Originally posted by russell_t View PostThanks for the Quickshot v2 rom! Donation sent. Received my new X7 Mini last week and flashed it later that same day. Looking forward to trying an OC kernel in the near future. Great work on the v2 rom, much appreciated!There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Flashing the Mini Neo-X7 Fails.
I have tried to follow the install instructions but there are problems.
1. No power button on my Minix NEO-X7 Mini.
2 I connect to the PC and it is seen as Mass Storage device but enclosed drivers are not accepted by Win 8 it says Best driver is installed.
3. In the Flash Utility it cannot erase the IDB therfore it cannot flash the ROM.
Logs:
07:19:36 916 Load Setting ok
07:19:36 940 RKAndroidTool v1.3.7.0 Start Run
07:19:36 940 Scan thread:37
07:19:36 943 ProcessID:35,ThreadID:37,RefCount:0
07:19:36 943 ProcessID:35,ThreadID:36,RefCount:0
07:20:28 344 Info:wait for exiting scan thread start
07:20:28 439 Info:wait for exiting main thread start
07:20:28 441 ProcessID:35,ThreadID:39,RefCount:0
07:20:28 441 ProcessID:35,ThreadID:38,RefCount:0
07:20:28 441 ProcessID:35,ThreadID:36,RefCount:0
I get the similar results with the Finless 1.8 ROM.
So where is the power button you talk about??
Added this info to the first page.
App to Spoof the x7 as a Nexus 7
http://codekiem.com/market-helper/latest
- open the app, select "Tablet" and "Nexus 7 3G", select your country and operator and click on Activate. You will be asked to visit the Google Dashboard, do it, just open the link and you're done. Go to playstore and try to download Real Racing 3, if it works then you succeed.There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View PostConect the usb male male cable to PC, power on the device, check the "connect to pc" to be enabled on android, shut down the device. Remove the power cable, now push the reset button on the bottom and insert the power cable while you hold the reset button. Windows should recognize it and ask for a driver. you can release the reset button at this point. The rest is quite obvious.
Thanks again.
Beer on it's way
Originally posted by daemonium View Postlook at this answer, and if it doesn't work, try it in a winxp machine.
http://www.freaktab.com/showthread.php?p=143134
Originally posted by Scarsax View PostIf u are in Spain a few beers on their way!!!There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by TVDroid View PostFirst i want to say, thanks for this ROM!
Next i have a Question, how i can replace the Pointer / Cursor ?
I edit the Cursor already but what is the best way to copy the Framework.res without get a Bootloop ?
Thanks !There are 10 types of people in the world: Those who understand binary, and those who don't...
Thank You !!
How i can do this ?
Or you can make a Script for me ?
Here the Pointer ...
And here the Framework.res with the Pointer in it. Click
Thanks a lot !
EDIT: The same with the Softbutton´s ? When i copy my SystemUI.apk than the Device makes a Reboot but starts fine with new Softbutton, but i think the best Way is that not ?
EDIT2: My left USB port dont working, i try the Fix but this helps not. Any Ideas ?Last edited by TVDroid; 15 February 2014, 20:06.... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
Originally posted by TVDroid View PostThank You !!
How i can do this ?
Thanks a lot !
EDIT2: My left USB port dont working, i try the Fix but this helps not. Any Ideas ?There are 10 types of people in the world: Those who understand binary, and those who don't...
it should work fine with the patch. did you reboot after the patch was applied?
also you can try to untick the "connect to pc" option under settings, usb.There are 10 types of people in the world: Those who understand binary, and those who don't...
There are currently 4130 users online. 0 members and 4130 guests.
