Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
Originally posted by grimace View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by PeterPan View PostHi,
when all fields are correctly filled just go one step back and a popup will show with option to save.
rgdsThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by Crashnet2000 View PostI cant get the systembar to autohide after autohide is set either in xbmc, homescreen... When Going to settings, netflix and other apps it autohides.. Am I missing something?To Infinity and Beyond.... XBMC
Originally posted by Crashnet2000 View PostI cant get the systembar to autohide after autohide is set either in xbmc, homescreen... When Going to settings, netflix and other apps it autohides.. Am I missing something?There are 10 types of people in the world: Those who understand binary, and those who don't...
Guest
Originally posted by daemonium View PostAre you playing from internal sdcard?
i'm asking thiw because you say : I play the file from the sdcard (NTFS) or USB HDD.
And this makes me think you are playing from external, since internal is not ntfs.
when booting to CWM I can't see the very left characters (maybe 3 or 4).
Same for the bottom line (I believe I miss 1 line).
Screen is adjusted correct.
Any idea?
rgds
have you tried another hdmi port?
maybe the tv is over scanning, my samsung does this and I change the name of the input to pc-dvi, and when the input is called pc-dvi, the tv thinks it's a computer input and doesn't overscan,
to do this use the remote and press the input select button, use remote to highlight the input( only works in hdmi 1 some screens) the when highlighted, press tools button on remote, the use rename to rename input pc-dvi, come out and choose another input then go back to the one you changed and if it has worked it will fit perfectly, the display will look much better and crisper, I did this to a friends display and he couldn't believe how much better it was!!
not sure how to do this with other screens but works with samsung??
Originally posted by pakman View PostSorry, yes it was through an external SD card plugged into the SD card slot. I can't test the particular mkv on the internal SD due to size but using some of the sample 1080p and 720p HD files located on this site http://www.auby.no/files/video_tests/ particularly Birds and Planet_2 clips, they play about 99% perfect (saved to both internal SD or USB thumbdrive) but if you look closely, I can catch a slight but very short stutter in some of the panning scenes. Tested on the android video player and on XBMC. I am starting to wonder if there are any background programs running that might be causing this. Or maybe I'm being too critical but then in my case, the main reason for getting this was to replace my current media player.
I usually test those videos over network via smb, so the stuttering is bigger than if you play local.
I'm sorry i don't have a proper solution for this.There are 10 types of people in the world: Those who understand binary, and those who don't...
Hey guys new to the site, just got the x7 mini, having a small problem installing quickshot. I cannot seem to get the RK Android Tool to recognize the device. Instructions say to push the power button, but obviously, there is none. I'm having issues even getting my pc to find the device, and yes I have connect to pc selected, I also have debug mode selected. Any advice would be appreciated, thanks!
Guys for some weird reason ,everytime I try to load the usbfix quickflaher.zip, Quick flasher keeps giving me this /mnt/extrnal_sd/quickflasher/usbfix_quickflasher.zip. Then I try to install and nothing happens. quickflasher tells me QF support with pro version to load packages in other locations. What am I doing wrong?
There are currently 3336 users online. 1 members and 3335 guests.
