Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
    Hi, newbie here! I just bought a clone called X5 ii (http://www.bee-link.com/goods.php?id=50). It has the same specs as the minix x7-mini.
    Will this ROM work on my device ?
      Re: Minix Neo X7-mini Quickshot v2 Rom by The Nitro Team
      Sorry, we don't know wifi, Ethernet and bt are the same and if some internal harware is.
      leolas.
      My devices:
      Gearbest.com)
        Originally posted by leolas View Post
        Yes. If you have your xbmc configured use xbmc backup pluggin to keep your settings.
        leolas.
        Ok thanks. Anyway to keep sound settings as the same when using an A2 remote?
          Great work team. Thank you. Any chance we can get something similar to MK802IV AP6210.
          Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
            Sorry, we don't have that tvstick
            There are 10 types of people in the world: Those who understand binary, and those who don't...
            If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
              Like daemonium said, we dont have that device, we ported the rom to X7 mini without the device and we had problems because we cant test it properly, is very hard to solve problems without the device
              leolas
              My devices:
              Gearbest.com)
                Look at your TV if you have a zoom option enabled.
                leolas
                Hi Leolas,
                shame on me
                Could solve the problem myself with "tuning" the TV
                Sorry and thanks for your support
                rgds
                  Thank you.
                  leolas
                    Originally posted by PeterPan View Post
                    Hi Leolas me on me
                    rgds
                    I too have the CWM characters off the edge of the screen, and a zoom adjustment worked for me until reboot...
                    Made sure the TV is saving the required zoomed setting.
                    Something to do with HDMI settings in rom/kernal???
                    EDIT- Must be the TV. Resets after turningTV off and doing nothing else...
                    EDIT 2 - Found a setting 'auto format' set to auto. Set to off - problem solved.
                      Hi Leolas,
                      shame on me
                      rgds
                      nice you find it
                      Thank you.
                      Great if I helps
                      Usually all tvs have zoom adjustment, but there is some old LCD tvs that can't zoom properly, i have one of them
                      leolas.
                      My devices:
                      Gearbest.com)
                        ethernet configuration
                        I've installed this ROM on my X7 Mini and it is working very well! Though, I am trying to set a static ip address for ethernet and can not seem to save my settings. I can set all the fields but there is no save button and when I leave the menu, nothing is saved. Does anyone else have this problem? Is there a work around?
                          try to play from the internal sdcard, i have a theory.. :P
                          Sorry for not getting back to you earlier. I did some testing, and the slight stuttering is the same whether I play the file from the sdcard (NTFS) or USB HDD. I also played the file on my PC to confirm it's not a file issue. Also, I confirmed when I view videos in my NFL Gamepass app on my Samsung Note 2 LTE and PC, there is no stutter. But on my Minix, you can see the slight stutter (for instance when there is a news ticker scrolling at the bottom. On the Note 2, ipad, and PC, the ticker scrolls smoothly whereas on the Minix, ticker moves across screen with a slight jerking motion.) I have tried various OC'ed kernels but there is no change. The videos are watchable but occasionally I'll see these small stutters.
                          Sent from my GT-N7105 using Tapatalk
                            IMPORTANT NOTES:
                            FIX FOR "NOT WORKING LEFT USB PORT"
                            Apply with quickflasher and reboot
                            http://ul.to/d03coz4o
                            XBMC updated to 12.4.0 & fixed:
                            Launcher version
                            https://mega.co.nz/#!6QNVxKjT!PJruD0...0JW2u3nCgvRayA
                            No Launcher version
                            https://mega.co.nz/#!XI9jDBTD!iWbEbN...ExzDxHY6dreu8Y
                            daemonium, can you make launcher version XBMC with russian keyboard support, please?
                              i'm afraid i can't since we are not compiling xbmc from sources. What we do is just a mod. Sorry i can't help
                                Are you playing from internal sdcard?
                                i'm asking thiw because you say : I play the file from the sdcard (NTFS) or USB HDD.
                                And this makes me think you are playing from external, since internal is not ntfs.
