It is better to flash the whole ROM if you flash the system.img. If you don't erase idb, you risk having leftover parts of the previous ROM. The only difference is that addition of the standard keyboard...and removal of a few Chinese apps.
Pipo M9 Pro RileyROM 2.7 KitKat
I didn't change the libril this time. Too many complaints from 3g users.
It is better to flash the whole ROM if you flash the system.img. If you don't erase idb, you risk having leftover parts of the previous ROM. The only difference is that addition of the standard keyboard...and removal of a few Chinese apps.Randy
Originally posted by rrileypm View PostThis KitKat ROM is based on a new test firmware dated 3/20/14. Thanks to Freaktab member Manao for contributing the link to this firmware. I like to give credit where credit is due, but I do not know the name of the Chinese developer who originally provided this ROM. He put a great deal of work into adding custom icons in the settings app. Kudos to him. If anyone can share his name with me, I will be happy to credit him here for his work.
Thanks, I will edit the OP with his name and give him credit.
Done!!!!Randy
Originally posted by maxmax View PostThe name of Chinese procucer is Edge Xuan
A fine ROM indeed. Smoothest one so far.
It's interesting how rk3188 shines on the Pipos where JB was pretty mediocre (understatement), despite being a far more mature platform.
It doesn't actually feel like the same hardware...
Another awesome ROM but this time from a chinese developer. I like the new settings icons much nicer UI. running fast and stable no major problems so far!
thank you randy for polishing this rom with your hands much appreciated and respect to you!
amen
GPS and Wi-Fi are great!PROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Re: Pipo M9 Pro RileyROM 2.7 KitKat
Originally posted by armspecial View Postone question
how i can change my pipo Mhz without changing Firmware
And does google now work in this Firmware ?
Yes, you can load Google Now on this ROM.
LDN
Sent from my Galaxy Nexus using TapatalkLast edited by LazyDogNet; 08 April 2014, 19:16.
Thanks for sharing. Hahaha!!!!!Randy
Originally posted by LazyDogNet View PostYou should be able to use any of the kernel mod apps out there like Trickster to change the speed (lower) or change other kernel parameters.
LDN
Just WOW
Randy, you're the man
My initial assumption seems to have been right
Deep sleep is enabled with this KitKat libril-rk29-dataonly file, and signal power is correctly reported to system (3-4 signal lines for me indoor).
20098 is my Antutu score
We have new settings to enable/disable 3G modem power and to choose between 2G/3G network types.
IMEI number is present, shown in "About tablet/Status" section.
This is by far the best M9 Pro ROM ever made.
I will post some screenshots later after more digging.
L.E
I found a bug, maybe is related to am incomplete dictionarry - Letter "Ț" (present in Romanian language) is missing sometimes in menu context
To enable Deep Sleep (only for those with M9Pro with 3G) :
1. Remove SIM card and insert only when needed.
When no SIM inserted modem power will be disabled by default
2. After every Sart/Restart enter in settings and uncheck Modem Power...i use 3G On/Off Widget by PotaLand ..just 2 clicks needed to enable/disable modem power (more convenient than wasting time to rename two different libril-rk29-dataonly)
This time I think the inability to store setting "modem power off" is not due libril file.Last edited by Edius; 09 April 2014, 00:27.
There are currently 3027 users online. 0 members and 3027 guests.
