Pipo M9 Pro RileyROM 2.7 KitKat
    Hi guys,
    Can anyone tell me if the keyboard vibrating/ shaking issue in acrobat (and a few other apps) is fixed in this ROM?
    A
      init.d not work
      Not running scripts Init.d
      In the script 95Mr_ZRAM there is a line
      echo "Enable ZRAM ok" >> / data /! Mr_ZRAM_OK.log
      Mr_ZRAM_OK.log file does not appear in the data
      means Init.d not working
      Fires subwords install busybox as sim link to xbin and application init d toogler
        Originally posted by andrewh View Post
        Hi guys,
        A
        Just tested it and no, it's still shaking.
          Experiencing Frequent Reboot
          Sir i was on Riley 2.5.2 version of Kitkat and had recently flash this 2.7 eventually after the first boot i signed in to play store to download my apps.. and then it just reboot, it never happened before with my old 2.5.2 version. and every now and then i randomly reboots... what could be the possible problem?
          my steps for flashing.
          1st erased Nand twice
          2nd flashed the rom
          3rd wait until boot
            Wifi Speed
            I have 2 Pipo M9-Pro and with this ROM it'seem that the wifi spedd is up to 150Mb/s on my 2 M9 and you ?
              Hi guys,
              A
              In other rom try check in development options: Disable HW overlays
              Always you reboot you must check.
              In this rom I don´t know if it´s fix, I don´t install it yet. I like know it too ;-)
                Read two messages above yours.
                  Init.d
                  you do not mind that half of optimization does not work?
                  so as not working Init.d
                  Waiting for an answer ....
                    I read that the device goes down to deep sleep, I must say that this version does no such thing. I flashed my device last night and it was on for 6 hours, I checked wakelock detector and it states "99% wake"
                    So what ever you did with 2.6 it worked, for me it's better with a low reception bar than a 99% wake state. I read somewhere that this could be reverted. Other than that the rom is perfect!
                    Thanks riley!
                    Skickat från min GT-I9300 via Tapatalk
                      google translate
                      you'll get sleep without much loss
                      You do plagiarism
                      not only root acess
                        Originally posted by bucefal82 View Post
                        Bucefal82, would you mind uploading the custom kernels posted on:
                        I think downloading from 4pda without being registered is not possible.
                        I tried signing up but google translate failed me at the registration page.
                        Would be a great help if a member could help me out
                        Cheers!
                          Just a dubious introduction root and init.d not working is not the reason for the name ReilyRom
                            Battery drains pretty fast on KitKat, I have to charge my M9Pro everyday. Which is the best governor and i/o scheduler to use?
                            Sent from my M9pro using Tapatalk
                            PROUD owner of PiPO M9 Pro
                            PiPO P9 best tablet ever owned!!!
                            PiPO Tablet Freak and Flashaholic!
                              Very Interesting.
                              You have also this trick http://www.freaktab.com/showthread.p...l=1#post160853 (from post #123 to #127)
                                Cheers!
                                This is the same ROM than the Chinese ROM
                                But in the Bucefal82 post you have two kernel added
                                - cpu_stock_gpu600_1250_ddr720_1175
                                - kernel_cpu-126-1416_gpu600_1250_ddr720_1175
