I'll like to install it, but first of all I'll like to know how it works on 3g version.
Pipo M9 Pro RileyROM 2.7 KitKat
Originally posted by belier View PostAnyone with 3g to share their opinion of this ROM?
As the post above states, QuickOffice is a problem.
When selecting Open or SaveAs, I get the "Unfortunately, Quickoffice has stopped" error.
So I have installed Kingsoft Office until (and if) I can resolve the QuickOffice problem.
Everything else seems to work pretty much flawlessly.
Originally posted by jimac View PostI am using it on an M9Pro 3G - mostly it is great!
Just installed it. Really smooth and fast, but...
As always, it could not be perfect.
I've two games that try to run on full screen mode.
But they freeze.
I need to make appear notification bar sweeping down to make it run again.
Once I release the notification area and it folds, games just freeze again.
So, if I hold notifications unfolded with finger, games run, but not playable.
They are Clash of Clans and Hay Day.
Is there any way to avoid these games running on full screen mode?
Other games doesn't do this
EDIT: Just googleing a bit, just found what happens:
Compiling with the new framework does not enable full screen mode automatically as claimed.
since last update Clash of Clans is obviuously doing it on purpose.
Clash of Clans is calling setSystemUiVisibility() with flags SYSTEM_UI_FLAG_IMMERSIVE, SYSTEM_UI_FLAG_HIDE_NAVIGATION to make it happen.
It would be very easy to add configuration option to Cash of Clans to let the user to decide what he/she wants since Clash of Clans is now also defining SYSTEM_UI_FLAG_IMMERSIVE_STICKY to make navigation bars to dissappear after a moment if summoned with swipe.
by defining SYSTEM_UI_FLAG_FULLSCREEN user could swipe the bars on screen and they would not dissappear without action.
Now that Immersive full screen is defined STICKY there is now way to externally control the behaviour.Last edited by belier; 11 April 2014, 12:45.
At least with ths ROM's version of KK you don't keep getting Google Now pushed at you all the time, as it does on my Nexus.
If I could manage to, I would go back to JB, probably Finless 1.5 but I have failed to manage to do that despite making several attempts.
Originally posted by kostasd View Post
Code:# begin build properties# autogenerated by buildinfo.sh ro.build.id=KOT49H ro.build.display.id=rk3188-eng 4.4.2 KOT49H eng.root.20140319.153242 test-keys ro.build.version.incremental=eng.root.20140319.153242 ro.build.version.sdk=19 ro.build.version.codename=REL ro.build.version.release=4.4.2 ro.build.date=2014年 03月 19日 星期三 15:33:23 CST ro.build.date.utc=1395214403 ro.build.type=eng ro.build.user=root ro.build.host=alex-System-Product-Name ro.build.tags=test-keys ro.product.model=M9pro ro.product.brand=rockchip ro.product.name=rk3188 ro.product.device=rk3188 ro.product.board=rk30sdk ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.manufacturer=rockchip ro.product.locale.language=zh ro.product.locale.region=CN ro.wifi.channels= ro.board.platform=rk3188 # ro.build.product is obsolete; use ro.product.device ro.build.product=rk3188 # Do not try to parse ro.build.description or .fingerprint ro.build.description=rk3188-eng 4.4.2 KOT49H eng.root.20140319.153242 test-keys ro.build.fingerprint=rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140319.153242:eng/test-keys ro.build.characteristics=tablet # end build properties # # from device/rockchip/rk3188/system.prop # # # system.prop # #rild.libpath=/system/lib/libreference-ril.so #rild.libargs=-d /dev/ttyUSB2 # Default ecclist ro.ril.ecclist=112,911 ro.opengles.version = 131072 wifi.interface=wlan0 ro.rk.systembar.voiceicon=true rild.libpath=/system/lib/libril-rk29-dataonly.so rild.libargs=-d /dev/ttyACM0 persist.tegra.nvmmlite = 1 ro.audio.monitorOrientation=true #NFC debug.nfc.fw_download=false debug.nfc.se=false #add Rockchip properties here ro.rksdk.version=RK30_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00 \ ro.rk.screenoff_time=120000 ro.rk.screenshot_enable=true ro.rk.def_brightness=200 ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home ro.rk.install_non_market_apps=false sys.hwc.compose_policy=6 sys.wallpaper.rgb565=0 sf.power.control=2073600 sys.rkadb.root=0 ro.sf.fakerotation=false ro.sf.hwrotation=0 ro.rk.MassStorage=false ro.rk.systembar.voiceicon=true ro.rk.systembar.tabletUI=false wifi.interface=wlan0 ro.tether.denied=false sys.resolution.changed=false ro.default.size=100 persist.sys.timezone=Asia/Shanghai ro.product.usbfactory=rockchip_usb wifi.supplicant_scan_interval=15 ro.factory.tool=0 ro.kernel.android.checkjni=0 #set default lcd density to Rockchip tablet ro.sf.lcd_density=240 ro.adb.secure =0 # # ADDITIONAL_BUILD_PROPERTIES # ro.com.android.dateformat=MM-dd-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.carrier=unknown ro.config.alarm_alert=Alarm_Classic.ogg dalvik.vm.heapstartsize=16m dalvik.vm.heapgrowthlimit=192m dalvik.vm.heapsize=512m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=512k dalvik.vm.heapmaxfree=8m dalvik.vm.lockprof.threshold=500 dalvik.vm.dexopt-flags=m=y dalvik.vm.stack-trace-file=/data/anr/traces.txt ro.hwui.texture_cache_size=72 ro.hwui.layer_cache_size=48 ro.hwui.path_cache_size=16 ro.hwui.shape_cache_size=4 ro.hwui.gradient_cache_size=1 ro.hwui.drop_shadow_cache_size=6 ro.hwui.texture_cache_flush_rate=0.4 ro.hwui.text_small_cache_width=1024 ro.hwui.text_small_cache_height=1024 ro.hwui.text_large_cache_width=2048 ro.hwui.text_large_cache_height=1024 ro.hwui.disable_scissor_opt=true ro.rk.screenshot_enable=true persist.sys.ui.hw=true ro.config.facelock=enable_facelock persist.facelock.detect_cutoff=5000 persist.facelock.recog_cutoff=5000 ro.sf.lcdc_composer=1 debug.hwui.render_dirty_regions=false keyguard.no_require_sim=true ro.com.android.dataroaming=true ril.function.dataonly=1 persist.sys.strictmode.visual=false dalvik.vm.jniopts=warnonly ro.rk.bt_enable=true ro.rk.btchip=broadcom.bplus ro.factory.hasUMS=true persist.sys.usb.config=mass_storage ro.factory.hasGPS=true ro.factory.storage_suppntfs=true ro.factory.without_battery=false ro.product.version=1.0.0 ro.product.ota.host=www.rockchip.com:2300 persist.sys.dalvik.vm.lib=libdvm.so ro.kernel.android.checkjni=1 net.bt.name=Android
Originally posted by elmachinegun View PostMine reboots every time I connect to a wireless display.
This happens also with my M7Pro RR 2.8 KK.
I put tablet to charge when powered on, after a few minutes i remembered to shutdown and received a reboot...tried 3 times in a row.
Disconnected from wall charger and shutdown works just fine.
This is an addition to post #13 from this thread, not a criticism.
Maybe base Rom used here by Randy was much too customised by his chinese creator, denoted by dictionary and keyboard disfunctionalities.
Mine too have some sort of trouble with Kingsoft Office on Word documents.."application has a problem... etc"
In my opinion these KitKat little flaws are minor vs. JellyBean ones.
On Arctablet has been posted a new/same Rom based on original Pipo dated 2014/03/19, probably without these minor bugs, link provided here on #81 _ costasd
Maybe Randy has time to remake and we will have a 2.7.2 version without glitches and with a new boot animation
If anyone can find a link to that stock version, I can make a new ROM without all of the Chinese tweaks.Randy
PROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
[QUOTE=rrileypm;166660]If anyone can find a link to that stock version, I can make a new ROM without all of the Chinese tweaks.[/QUOTE
Dear all,
This is the link for the latest rom: http://vondroid.com/attachments/2014...-404-rar.5805/
There are currently 1829 users online. 0 members and 1829 guests.
