xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
Originally posted by Nowandlayda View PostCheck out what stane1983 has been up to http://www.cnx-software.com/2014/09/...s802-released/ . Its a patched XBMC Gotham 13.2 for s802 with backports from Kodi alpha allowing 4K.
Are you using stane's build? if so please give some feedback, what's performing better
nope. I'm still happy with stanes AMLinux. He is working on a new armhf build (hopefully a full linux distro w/ dual boot android). Well see. He's a busy guy. On top of visontech firmware he is a main contributor for amlogic xbmc compatability. With so much going on with the changeover to kodi he has been slammed.@µ$ł!Ω
Adding TV show to XBMC Library taking 20-30 minutes each
Just updated from Leolas 1.1.0 to Leolas 1.2.0 on my Tronsmart S86 Vega, and updated from Oman's XBMC v13.1 to v13.2 and seeing a strange set of symptoms. When I click to add a TV series to the Library, it takes 20-30 minutes to add it. Then, if I subscribe to it so that I get the new episodes, that takes maybe 10-minutes after which it 'scans for new media', which takes about 30-minutes more.
Thought it might be network related so I ran Speed Test and its downstream was approx. 19 Mbps and upstream approx. 17 Mbps, both slightly faster than my previous testing on the previous versions which worked fine, taking maybe a minute or two to add a show with multiple season and maybe 15-30 seconds to subscribe.
Any ideas? Movies worked fine, but use this mostly to watch TV series, so this is a serious challenge.
Thanks in advance for any assistance offered.
Re: xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
Originally posted by oman View Posthi Folks.
xbmc-13.2-Gotham-4K-video-2160P-output->
based on xbmc-13.2-Gotham-armeabi-v7a
1.Decode 4K video;
2.Fix playing video 1/4 issue when HDMI 2160P/720P output;
3.Add system authority to xbmc,so it's no need to root Android;
<-Download Here->
xbmc-13.1-Gotham-4K-video-2160P-output->
based on xbmc-13.1-Gotham-armeabi-v7a
1.Decode 4K video;
->Download Here->
Sent from my GT-I9505 using Tapatalk
Originally posted by glenngaucigrech View PostGoogle it .. its like an i tetlace problem . U get thin lines horizontal when ur in a fast scene its a lot worse
Originally posted by glenngaucigrech View PostAh shoot thats how i spelled it ? Yes intetlace .. was sposed to be interlaced .. but in this oman version with 2160p in both 13. And 13.2 it has no options for interlacing .. and vertical sync is enabled
Good Luck
There are currently 3009 users online. 4 members and 3005 guests.
