xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
    Originally posted by oman View Post
    Here is the link:https://www.dropbox.com/s/ottkh966t9...40513-oman.apk
    Pls try and test it.
    Good news and bad news:
    Previously my video was black and audio was fine - that has been fixed, thanks!
    BUT
    Bad news is when I am playing a video and choose the Audio or Video icons in the playback menu, XBMC crashes immediately. This is repeatable.
    I guess it's because of the alpha build... dang.
    I wonder how to get the video playback working on a stable xbmc build, anyone?
    tx
    Mark.
    _________________________________________
    Out: USB audio, HDMI
    In: Logitech K400 keyboards
      Originally posted by fredphoesh View Post
      BUT
      tx
      Mark.
      install his 13.1 build.. his 14 alpha is what causes it to crash.
        Amlogic s802 M8 addons stuck at Downloading 0%
        hi Folks.
        I git clone xbmc source code from xbmc official website to 20140512,and did some modify.
        It can play 4k/rmvb/h265 video instead of invoking mxplayer.
        I installed the (xbmc-for-amlogic-20140513-oman.apk) after updating the firmware to (K200-OTA-20140518) and everything seems to be going good but I cannot install any addons. No download will install. They are all stuck at Downloading 0%. I have installed xbmc on my Windows and my Mac and I have them running good. This M8 box is a lot slower when downloading anything but why is every add on download stuck at 0%? I have tried using wireless and ethernet and neither will work. What would be a cause of all downloads to get stuck at 0%?
          Hi and thanks...
          I found a nightly release that works... at the moment I dont have any need for 4k (I would need better eyes to start with
          tx
          Mark.
            R: xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
            Try to download the addon separately(in zip format) from superrepo....and then install them manually. For me works with 1 channel
              Re: xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
              that's what I have to do with 1channel also. for some reason that one never auto updates
              Sent from my SM-N9005
                XBMC Oman Version....final 13.1 ?
                Pls test the xbmc-13.1-Gotham-armeabi-v7a-oman
                No support for 4k/h265 videos.
                Hi Oman,
                Your XBMC 13.1 version, that's based off the XBMC final 13.1 right?
                Used it the other night and it worked great btw. Thanks for all your hard work.
                  XBMC v13.1
                  If you use the fast forward buttons, after a couple of fast forward or fast seeks, I find the video looses integrity (meaning video starts to bleed). Anyone know how to fix this? or if this is a firwmare problem. Using Finless 1.7.
                    1.7 problem , issue with codecs, its hit and miss at moment, some users get good playback , others not so good, most will recommend 1.6 for now.
                      Originally posted by TMx View Post
                      I've notice a problem;
                      If I change the resolution to 720p XBMC menus are ok but Movies are not Centre the screen ...
                      looks like picture 4x bigger than the screen and only 1/4 of the picture watchable .
                      Gotham RC also same but 720p videos working ok
                      Oman's apk is the only build with working HW decoding on my S89 tronsmart.
                      Unfortunately it's still unusable because i have the same problem as TMX , video doesn't fit the screen.
                      I can't change the resolution (1080p).
                      I use the last firmware 105k4 not rooted.
                      I tried alpha14 and 13.1 Oman's build.
                      Changing to software rendering doesn't seem to change anything.
                        Full 4k screen
                        hello
                        Does anyone knows if this feature (4k fullscreen) will be added soon ?
                        Thank you and grat job !
                          Originally posted by gregdeberg View Post
                          hello
                          Find it in the first post in this thread..
                          Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
                            Great , thank you
                            Another question with no relation, do you know if the amlogic S802 is capable of decoding hevc codec ?
                            have a nice day !
                              回复: xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
                              Great , thank you
                              have a nice day !
                              I know s812 can do that,but we havnt got that sample
                              来自我的 GT-I9300 上的 Tapatalk
                                Ok but not the S802 so ?
                                thank you
