xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
Originally posted by oman View Posthi Folks.
I git clone xbmc source code from xbmc official website to 20140512,and did some modify.
It can play 4k/rmvb/h265 video instead of invoking mxplayer.
Here is the link:https://www.dropbox.com/s/ottkh966t9...40513-oman.apk
Pls try and test it.
Originally posted by eugene2878 View PostOman. Can you get modified final Gotham release instead of alpha? Could someone share apk with Gotham final hacked to work on s802?
If you indeed want,I think TMx can do thatEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View Post1.It can play most of different videos,include 4k/rmvb/wmv/mkv/avi/mp4/m2ts/h265 and so on,also support Dolby and DTS.
2.No video audio aysn issue.
3.No need to root the device.
4.No need to change any settings.
Just uninstall old ,and install this..
BTW,I am reading the xbmc source code recently,I want to improve something ....
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostMay I ask why you choose the Gotham 14 alpha instead of the gotham 13.1 at the time to build your xbmc, it works great but was curious
JustMe
2.rmvb
3.muti AAC
thanks oman pls don't get wrong for asking i was just wondering and your version has worked great. +1 been testing it since you released
JustMe
JustMe
oman or lokie, quick question. If I remember correctly amlogic devices use amlcodec instead of libstagefright and mediacodec. This is obviously kitkat on amlogic s802. In this version of xbmc the default is set to allow hardware accel over amcodec not amlcodec with both libstagefright and mediacodec enabled. Kitkat uses mediacodec but I noticed on the stock 102k4 rom that in system/lib libstagefright.so still exists. for hardware accel what needs to be enabled? im assuming amcodec but does libstagefright and mediacodec need to be enabled as well?@µ$ł!Ω
Originally posted by Nowandlayda View Postoman or lokie, quick question. If I remember correctly amlogic devices use amlcodec instead of libstagefright and mediacodec. This is obviously kitkat on amlogic s802. In this version of xbmc the default is set to allow hardware accel over amcodec not amlcodec with both libstagefright and mediacodec enabled. Kitkat uses mediacodec but I noticed on the stock 102k4 rom that in system/lib libstagefright.so still exists. for hardware accel what needs to be enabled? im assuming amcodec but does libstagefright and mediacodec need to be enabled as well?
amlcodec=amcodec?
But other media player App may use libstagefright.so.
Enable libstagefright and mediacodec will be fine,just leave it to be default.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
from previous geeksearch on amlogic devices (pre kitkat) I know enabling libstagefright messed things up. Just from what I've read amlcodec should be enabled for proper xbmc accel. I've always been a windows .dll or samsung exynos guy so I'm just curious. Can anyone confirm enabling amcodec mediacodec and libstagefright works. I'm away from my box so I can't debug. Just curious@µ$ł!Ω
Running finless 1.5 with cpu_patch and XBMC gotham beta 2.
Setting amcodec in XBMC settings produces pause-like-buffering output in some 23.976fps movies. From what I've gathered from another post amcodec is not yet good to use for S802.
However enabling libstagefright plays all videos smoothly through XBMC's internal player (one 1080p video rebooted the machine, on second trial it played normally). Mediacodec crashed XBMC in some movies. The same happens with oman's version.
Also the quality is is almost the same using all three codecs.
A small note is that using either 720p@60Hz or 1080p@Hz made no difference in using these codecs meaning that something bad is going on inside XBMC handling amcodec properly.
So for the time being libstagefright is safe to use for smooth general playback, until bob or oman or someone figures out what is going on with amcodec.
There are currently 1421 users online. 1 members and 1420 guests.
