xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
Originally posted by oman View Post2.No video audio aysn issue.
This xbmc version and the preinstalled 14.0 alpha 1 oman, the official 14.0 alpha 2 and the official 13.2 give me all the same problems on my av-out: audio out of sync and horizontal tearing when camera is moving.
Is this a rom problem or av-out problem or do I need to use another xbmc version?
Wim
Originally posted by WimK View PostI have installed the 13.2 version in post #1 on my s89-h with 107k4 rom from june.
Wim
Originally posted by Blindseyed View PostSorry for the dumb question TM but what do u mean "FWs" ?
I'm getting the interlace problems also
and I think he means "use everything but not the last 2 FW's at the square one box (released at 08.2014)"RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostFW => FirmWare => OS => OperatingSystem => e.g. Android....
any ideas where to get the older firmware? I only started having the interlace problem when I flashed to finless 1.8 maybe I should use 1.7?
Any ideas would help since I'm learning all this as I go
I don't own the square M8 (Tamato/ENY) but if I remember correctly 1.7 is "state of the art"...RK3288 Devices
Originally posted by no_spam_for_me View PostI don't own the square M8 (Tamato/ENY) but if I remember correctly 1.7 is "state of the art"...
Also for anyone else having the interlace problems, use the Finless 1.7 , install the xbmc helix alpha 2 and only use libstagefright UNCHECK amcodec and MediaCodec, that solved my interlace and stuttering problems so far
Problem xbmc M8 MX Amlogic Android 4.4 Kitkat Quad Core
Hello
I have a box M8 MX Amlogic Android 4.4 Kitkat Quad Core 4 k 5 g Wifi TV Box XBMC Media Player and installed the latest version of xbmc, a nightly Kodi of 29 August. I can watch movies, but I have to have the amcodec off to see image. It turns out that some 720 p movies creep and I saw a forum to enable Libstagefright and so I can see all movies 720 p 1080 p movies, but the box restart. How can I fix this? Being a box amlogic shouldn't have the amcode enabled?
I have many ORIGINAL SQUARE M8 units by ENY/ACEMAX & I had recently updated them to the latest 0807-2014 Firmware from ACEMAX and well XBMC's hardware decoding went right out the window!! that is until I came across
OMAN's xbmc-13.2-Gotham-4K-video-2160P-output-> based on xbmc-13.2-Gotham-armeabi-v7
Ive got a restored faith in these units again!
OMAN Thank you soo much, and thank you to ALL the other Dev's and users on there that make up this wonderful community!
OMAN Donations are enroute
Originally posted by maroot View PostHow can i change this option in the xbmc version that came with finless 1.9 ROM?
Then go to eccelaration where you can enable/disable option. I am not sure if this makes any differences. If you screw up the settings, just set them back as defaults
Check out what stane1983 has been up to http://www.cnx-software.com/2014/09/...s802-released/ . Its a patched XBMC Gotham 13.2 for s802 with backports from Kodi alpha allowing 4K.@ยต$ł!Ω
There are currently 2614 users online. 0 members and 2614 guests.
