xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
Originally posted by warlock09 View PostHello oman,, Are we looking at oman's KODI 14.1 build soon??thanks
Originally posted by killajay89 View PostDoes the crinchyroll add on work on this? Also is this faster then openelec? (This is the most noon question I asked in a long time)
As to if its "Faster" I doubt anyone here could even give you a definitive answer to such a question as like so many others here, having just the One Box. So probably just as fast either way then..
Originally posted by nifedipin View PostGuys,
Where could I find a xbmc which can Play 4k/rmvb/h265 video on amlogic s812 platform?
Thanks,
N
P.S.I own a minix x8-h plus.Stock rom.
I'd also hitherto suspect that you'd have to take your question back to Minix... Assuming they, unlike their peers... Actually do more with the Amlogic Firmware, then slap on a Boot Logo, and custom skin. To add the eventual *.rmvb codec into the main amcodec. Where Applications such as XBMC/Kodi eventually call upon it.
You might also want to give Antutu Video Tester... a spin. it should play a list of videos... Some of which are in *.rmvb and report on its playback. Assuming your "H" Chip is all that... Those segments should run smooth like silk. Unlike the flip frames I get on my S802 (MXIII)
I just received my Minix the day before yesterday.
Basicly every xbmc version works fine,except BeyoundXbmc[choppy].
I enabled amcodec option every time.When it's disabled hd mkv runs choppy!
Amcodec has some kind of a BUG!
With amcodec enabled when watching 3D mkv[SBS} I can NOT activate 2D mode-aka watching A HALF image in full screen!
So I need overclocking AND NO HDCP! [My Xperia z3 Black gives me a warning when connects via Miracast to Minix]
I'm thinking to try Finless Bob Rom 1.1.
Sadly NO dts-ma and DolbyTrueHd passthrough[eternal Android issue!].No 3d BR playback[weird].
But wifi and Gigabit Lan are GREAT.!
Till now I used a Tronsmart 908 II [RK processor] with Finless Bob Rom 1.6,cpu overclocked,Ram overclocked.The only xbmc version runing smooth was SPMC 1.3.3.Weak wifi,NO lan--I had to "inject" a driver and to put a script in "initD" for getting the ethernet to work[with a LogiLink usb2Ethernet adapter].I was almost happy with my Tronsmart......R.I.P.!
N
P.S.I'll try antutu video tester.
There are currently 2952 users online. 0 members and 2952 guests.
