xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
    picture and sound ok @720p menu navigation in xbmc seem more responsive from few test sync look ok time will tell and more users testing
    +1
    fantastic comunity
    JustMe
    Bugs are Sons of Glitches!
    JustMe
      Originally posted by oman View Post
      Pls test the xbmc-13.1-Gotham-armeabi-v7a-oman
      No support for 4k/h265 videos.
      Thanx Oman Subtitles working perfecty , all good here...
        It's SW decoding.
        S812 can support HW decoding.
        Ah, ok. How high of a resolution and bitrate does it handle for H.265 using SW decoding? Have you tested it enough to find out?
          Thankyou!
          XMBC 13.1 works well. I did notice you can't play m4v, but I think that's a limitation of the amlogic.
          tr.
            tr.
            Aren't m4v files just MPEG4 video streams and AAC audio streams in an Apple container? If so, I don't see why it wouldn't be able to decode the video and audio if it has the appropriate splitter (which is something provided by the application or OS, not the hardware decoder).
              This would be a much better thread on xbmc forums. If you want specific device support, all the xbmc devs are looking there... Oman and stane great work, but redirect this thread to the official xbmc for android thread so logs can be implemented in future gotham/helix development.
              @ยต$ł!Ω
                silly Question ...
                I cant find my userdata folder from esexplorer
                Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
                XBMC on :
                Tronsmart S89 Quad Core - Openelec
                Atv1 + Crystall HD - Crystalbuntu
                Raspberry Pi - Openelec
                Xios DS - Linux the-hydra
                1st gen xbox, JB Atv2, Ouya, ...
                  android/data/data/org.xbmc.org/.xbmc/userdata (somthing like that away ffom device) make sure you show hidden files
                  @ยต$ł!Ω
                    there was es-explorer weird problem , and was not refreshing the folder
                    oman, thnx to your awesome works
                    are we gonna get xbmc linux which you started to compile the kernel long ago ?
                    I saw it in git : https://github.com/oman007/s82_kernel
                    XBMC on :
                      XBMC Linux?I don't understand what's this mean,I just opened this kernel for other developer to use.
                      I know there exist a Launcher version for XBMC..
                      Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
                        its a light weight Linux with only xbmc gui to run a fast xbmc
                        we all know android limitations ( 1080p 24, DTS-HD, True-HD Audio ... )
                        Sam Nazarko's crystalbuntu for atv1 and raspberry pi, the-hydra for xios and many others are same
                        XBMC on :
                          any chance to add 4K support to 13.1 ???
                            I believe that is only a feature they will be bringing to helix not gotham. However if its a simple .xml fix instead of a xbmc system or system lib fix then instructions would be great. haven't really looked around on xbmc xmls since frodo but i remember if you created an advancedsettings.xml it would take precedence over the guisettings. There you could set max resolution and framerate settings for different video formats. If I remember correctly guisettings.xml and advancedsettings.xml don't play well together in gotham. So maybe there might be guisettings tweaks that can potentially fix this in gotham? wiki.xbmc.org probably has a current tutorial on gotham tweaking...
                            @ยต$ł!Ω
                              After some testing in my measy b4a works great thanks oman
                                Oman's 14 Alpha release plays 4K files Ok, checked .xml files and its not xml level tweak...
