xbmc which can Play 4k/rmvb/h265 video on amlogic s802 platform
And s802 can support 1080P 24Hz,and also support DTS-HD,True-HD with XBMC..
Originally posted by TMx View Postany chance to add 4K support to 13.1 ???
Originally posted by Nowandlayda View PostOman we can use your expert advice in the Different firmware, different behavior thread. There is a lot of confusion and I have a feeling you can clarify.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
oman, I'm aware of this. I was wanting your input on this thread http://www.freaktab.com/showthread.p...erent-behavior . i think only you and lokie can clarify. it pertains to your kernal/firmware@µ$ł!Ω
Originally posted by oman View PostIn my opinion,Raspberry Pi and xios are assembled with low HW configuration,so using linux may help them to faster..
I'm starting to like my xbmc under android, I set my home to xbmc so it boots to xbmc and also I can run my android apps from programs menu. but how many times I use those apps ? lol .... almost never.
I think a solid xbmc box under linux would be much more stable and faster than xbmc under android.Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
XBMC on :
Tronsmart S89 Quad Core - Openelec
Atv1 + Crystall HD - Crystalbuntu
Raspberry Pi - Openelec
Xios DS - Linux the-hydra
1st gen xbox, JB Atv2, Ouya, ...
Originally posted by papampi View Post... I think a solid xbmc box under linux would be much more stable and faster than xbmc under android.Last edited by no_spam_for_me; 16 June 2014, 12:27.RK3288 Devices
- Overview BOX (LINK !)
true hd is a terminology used for windows xbmc from what I've dealt with in the past (a setting in xbmc). As far as your other problems use the default confluence skin and select expert to gain more control over your settings if you know what your doing. Also ensure your android settings are correct. Everything will get better but this is nothing compared to a high end NUC. Trust me this is early development for a new SOC.@µ$ł!Ω
Guest
The biggest technology standard battle of all time will be who wins smart TV by numbers ie: global user base. Apple Google & Microsoft have 3 top secret projects on Smart TVs unrelated to what they offer publicly now. Samsung and Sony also have smaller secret projects. Winner will rule the future as it spreads to other devices. I think the winner will not be the above or the best which would be a Linux version.
It will be future and totally different versions of Android + XBMC.
BTW just got my M8 today and this XBMC version is running great. Thanks oman.
is it possible to have the option for put display to sleep when idle in Settings > System > Power Saving same as xbmc on other devices like crystalbuntu, Raspbmc, xbmcbuntu, ... ?
when idle time comes up xbmc just minimze or quit to android and android ui wont sleep and keep TV and AVR on.Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
XBMC on :
btw, your xbmc 14 used to crash when trying to access video and audio settings menu during video playback using aeon nox skin but this 13.1 version works great so far good job
Originally posted by Nowandlayda View Posthe answered that earlier on in the thread. Initially I thought to only enable amcodec and mediacodec because amcodec is obviously for amlogic and mediacodec is for kitkat, but oman said enable all because different videos use different codecs (from what I understood from him)
There are currently 2993 users online. 0 members and 2993 guests.
