Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by B-Man View PostYou know what else I'd like to see in a ROM, I'd like to see customizable on screen soft key buttons. I have a Samsung phone and I'd like to have my Nextbook have he same soft key layout since I'm used to it.
If you don't know what xposed is, you should learn right now. Google it.
ShaunMTFreaktab Rom Developer
More update questions
Originally posted by shaunmt View PostI'd be surprised if there isn't an xposed module to take care of that for you.
ShaunMT
Anyone know a way to get them back?
ShaunMT
By the way, how is the ROM coming?
Originally posted by B-Man View PostI'll take a look. I played around with Xposed a little before on my Galaxy S4 before I decided to install Cyanogenmod 11. Thanks!
I've figured out how to make an update.img that is flashable using the stock recovery, which means we won't need a PC to install custom recovery or root. This is going to make it so much easier for everyone.
I've also figured out how to resize the partitions. It looks like I'll be able to offer several different options for the size of the /data and /sdcard partitions. This will just require a flash, followed by a factory restore and SD card erase.
All I've got left is to mod the system, test everything, package it all up, upload the files and post the links.
Originally posted by shaunmt View PostMy ROM for this model is progressing quickly...
ShaunMT
And when do you expect your custom rom out? I'll be one of your guinea pigs on this one.NEXTBOOK NX700QC16G Rooted with updated firmware to allow 13GB App Space
Re: Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by RosaFang View PostWith your mods, will it be possible to have the external SD card be the only SD partition and have the internal SD space (currently a extra 4.7 GB or so) be turned into app space? That's the only thing I would like to have happen since Nextbook/Yifang/Digiin just doesn't give us enough app space currently with only 1GB currently partitioned.
I havent yet tried but it might even be possible to use the external sd card as the primary and only sd card space.
Im off work this week so I might have something ready for this weekend.
Sent from my SM-G900P using TapatalkFreaktab Rom Developer
Originally posted by shaunmt View PostYes, I have successfully moved some space from sdcard to data for more app space. I will be able to provide some different sizes to choose from.
Thanks for any help you can provide.
Originally posted by Exile1975 View PostSorry to be new to the community and already asking for things, but... Would it be possible to make an update.img to root the new 4.4.2? Just root, no modifications? Last night i managed to unpack the update image and the system.img inside that before realizing i can't add su without being able to set permissions. I'm on windows 7 and can't find a way to edit an ext4 img...
The biggest challenge I'm seeing right now is a new one... The stock recovery has the really cool feature to flash Rockchip update.img files right from recovery. This usually requires a PC to do. If we replace the stock recovery with a standard TWRP recovery, we will lose that feature.
I really don't want to lose that feature, because it is the only way to flash the parameter file which defines the sizes for the partitions, and I expect that people will want to experiment with different parameter files with different sizes for /data and /sdcard.
I don't want to support the use of any of the PC flashing tools, because it would consume too much of my time. I also don't want people to have to flash back to stock recovery just to flash an update.img.
I found some Rockchip source code that includes the recovery with the rkimage flash feature. I'm hoping I can add the feature to a custom version of TWRP so we can have the best of both worlds!
Rooting...
Originally posted by shaunmt View PostI found the setting to erase SD... worked for me too...
I haven't tried Oma's custom, but I believe it requires some variety of the RK Flash tool to install from a PC, which would require drivers.
I used the Moborobo windows app which automatically installed drivers under windows 7 for me when I was trying to root the new update.
ShaunMT
ShaunMT, how did you end up rooting this tablet? Just curious if 4.4.2 was a more difficult OS version to root.
Is this tablet worth buying? A custom ROM would sure go a long way. I wasn't interested this tablet until now!
MoeFoh
Originally posted by MoeFoh View PostShaunMT, how did you end up rooting this tablet? Just curious if 4.4.2 was a more difficult OS version to root.
MoeFoh
I haven't found any working exploits for the 4.4.2 ROM, but I am able to flash the unrooted tablet. I'm planning to provide a pre-rooted rom as well as a flashable patch like my kyser_root patch.
I think it is a nice device for $99 from the local Wal Mart. My local Wal mart recently redesigned their product displays and now has live demo tablets on display. You might be able to play with one on display at your Wal Mart.
Greetings all! I registered today to thank you ShaunMT for the development you are putting into this tablet. It is great so far for a budget device, but it needs some serious help in the partition department. I also have a question and hope to get a good answer:
Will your upcoming update.img file work on a tablet that was updated to 4.4.2 since that killed root? I updated before I rooted, and found out the hard way that kingo is now a no-go. I have ART enabled and that left me with only 500mb available for apps.
Looking forward to your ROM!
-Jeff
Originally posted by AMMO View PostGreetings all! I registered today to thank you ShaunMT for the development you are putting into this tablet. It is great so far for a budget device, but it needs some serious help in the partition department. I also have a question and hope to get a good answer:
-Jeff
Yes, I also updated to the official 4.4.2. It will still be possible to get root and everything else. It will also be possible to make the internal sd card smaller in order to make more space available for apps.
Originally posted by B-Man View PostI haven't updated to the 4.4.2 stock KitKat firmware because I'm waiting for your ROM shaunmt. I am curious tho, its the way to access recovery the same on 4.4.2 as it was on 4.2.2?Freaktab Rom Developer
There are currently 1798 users online. 1 members and 1797 guests.
