Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by shaunmt View PostNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
AML8726-M3 Cortex A9 @ 1GHz
Nextbook Premium 8 HD (N0008HD8G) - * ROOTED *
Nextbook 8 (NX785QC8G) - STOCK (unfortunately)
Does anyone have recommendations for a case?
I'd like to get one that protects the corners, since it appears this is where my last tablet made contact with a tile floor and cracked the entire screen. Yes, it was in the case when it broke!
I've seen a lot of cases on **** and Amazon.com but nothing made by Nextbook. Walmart sells the tablet but no case for it, of course, just like the last one.
FYI, I'm leaning towards this one:
Re: Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by eegorr View PostShaun, if all we want is the stock v4.4.2, rooted and with a larger app space (say 2GB), should we update now and wait for your tweak?
Just be aware that you will have to do a factory reset to install the rooted version or change the partition layout.
I should have some sort of rooted update available by tonight.
Maybe a few days for twrp recovery, partition size changes and a fully modified rom. Not sure how long it will take to get all of it ready.
So far development is going smoothly and relatively quick considering my limited time.
Sent from my SM-G900P using TapatalkFreaktab Rom Developer
Nextbook 8 (NX785QC8G) + Towel Root
Has anybody used Towel Root on their Nextbook 8 (NX785QC8G) tablet to see if it can root their tablet?
Works on kernels earlier than June 3, 2014.
Exploit is from George Hotz, the famous iOS jailbreaker and PS3 hacker.
No PC needed, just download the tr.apk to your tablet from the website, install and run.
I just rooted my Nexus 7 (2013) tablet which runs KK 4.4.4 using Towel Root. Worked great. SuperSu, Busybox, ROM Tool Box Pro and Titanium Backup Pro all installed without incident.
MoeFoh
Originally posted by MoeFoh View PostHas anybody used Towel Root on their Nextbook 8 (NX785QC8G) tablet to see if it can root their tablet?
MoeFoh
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostMy ROM for this model is progressing quickly...
I've figured out how to make an update.img that is flashable using the stock recovery, which means we won't need a PC to install custom recovery or root. This is going to make it so much easier for everyone.
I've also figured out how to resize the partitions. It looks like I'll be able to offer several different options for the size of the /data and /sdcard partitions. This will just require a flash, followed by a factory restore and SD card erase.
All I've got left is to mod the system, test everything, package it all up, upload the files and post the links.
ShaunMT
Any update on the status of the img for 4.4.2 I know I hate when people keep asking me for updates but im just curious if you hit a roadblock on this
Originally posted by jrubin View PostAny update on the status of the img for 4.4.2 I know I hate when people keep asking me for updates but im just curious if you hit a roadblock on this
I'm pushing hard to get at least some of the files released tonight or tomorrow, but I've also got household chores to do and a business event to attend tomorrow.
Originally posted by shaunmt View PostNo roadblocks, just really busy this week with work, school and family... been too exhausted to stay up and work on it at night instead of sleeping.
ShaunMT
Is it possible to configue the update so that we have the option to save what we download directly to the external SD Card?
For app installs, it should be possible to load a modified parameter file to move most or all of the internal SD space to /data for apps and then load another patch to either swap the internal and external mount points or mount the external card only. I have not yet tested these scenarios though.Freaktab Rom Developer
i was just about to update my firmware. i have 6 min before the dl is complete. guess i will be holding off for now.
ditched the ipad for a nextbook nx785qc8g-b from walmart. the ipad was my son's and the problem was you give him the tablet and tell him to work on some math and before you know it he's trying to explain how angry birds is just basic geometry. needless to say i needed something where i can put the games on an external card and the school stuff on the internal storage. that way i can remove the game option from the device by just taking the card. everyone said "you can do it", however i am running into some problems.
first question: what's the purpose of telling me that i'm moving to sd card when really i am moving to NAND? second: what's the purpose of two internal partitions? when i reset to factory default it all goes bye bye.
third: is it possible to store and run apps off of an sd card? school has already started here and my son benefits from having the device due to his
i have figured out how to get into the developer options to set usb debugging (what ever that's for) and i have tried to follow anything i can find, however nothing i have come across is successful. this is what i am currently frustrated with... https://www.youtube.com/watch?v=CVOj2WnEeLw.
Originally posted by rraustin2 View Posti was just about to update my firmware. i have 6 min before the dl is complete. guess i will be holding off for now.
Many devices today, including all of the Nextbook tablets, have an internal NAND partition mounted as an internal SD Card, plus an external SD card reader...
Android only supports installing apps in /Data or /SD Card (the primary internal SD card).
On this model, it might be possible to create a patch to remove the internal SD card partition, increase the size of the /data partition, and then mount the external sd card as the primary SD card, but I haven't done any testing of this yet...
Originally posted by shaunmt View PostThe problem is that the Android operating system doesn't fully support multiple SD cards.
ShaunMT
Originally posted by shaunmt View PostFYI
The official update breaks root and Kingo root no longer works.
You may want to hold off on the update.
We'll have to make a pre-rooted ROM that can be flashed.
ShaunMT
There are currently 5373 users online. 4 members and 5369 guests.
