Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by B-Man View PostWe REALLY need the entire internal storage to be the data partition and the external SD to be the only SD. This is how my Galaxy S4 is due to Cyanogenmod, and it's wonderful. I still managed to almost fill up my data (entire 16GB internal storage) with apps. It was a shock when I bought this tablet and how little apps I can put on it.Freaktab Rom Developer
Originally posted by Perfectpitch View PostWhat if I have cwm already installed. Will I be able to flash your update via cwm?
As an alternative to the stock recovery, it should also be possible to use many (possibly any) of the various rockchip PC flashing tools to flash via usb.
ShaunMTFreaktab Rom Developer
Originally posted by dcc905 View PostCan anyone give instructions to root this tablet? If they are posted here I must have missed it. Links to the files would be great too. I installed the update already.
If you've got android version 4.4.2 nothing seems to work... you'll need a custom pre-rooted ROM. I thought mine would be ready to upload tonight, but I found a few more things to modify and I'm too tired to continue tonight... I expect to wrap it up and get it posted tomorrow...
Re: Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Shaunmt here is a link to OMAs ROM with cwm. His CWM is included in the download zip. It has a flash update.zip from sdcard. Though I have personally not tried that yet on it. I always flashed with rktool. If it works maybe it would help you with twrp. Just a thought.
Originally posted by Perfectpitch View PostShaunmt here is a link to OMAs ROM with cwm. His CWM is included in the download zip. It has a flash update.zip from sdcard. Though I have personally not tried that yet on it. I always flashed with rktool. If it works maybe it would help you with twrp. Just a thought.
http://forum.xda-developers.com/showthread.php?p=54124726
I'm now working with Abdul's device tree, and TWRP is booting successfully, but needs some tweaks for all the common TWRP features to work on our devices...
unfortunately, neither CWM or TWRP fully support all of the rockchip firmware parts, which means we will probably always need either stock recovery or a PC flash tool to flash things like parameter file, bootloader, or stand-alone kernels...
Originally posted by mel4787 View PostWe need to take the device properties and apply it to the cwm or twrp tree
I'm partially done with it, just a few more changes needed to fix the mount points and such... and possibly add some custom mountpoints.
Then I need to decide if I want to try porting any additional Rockchip specific features from the stock SDK or not... I'd really like to add the ability to flash update.img formats to TWRP, but not sure how much work would be involved.
Originally posted by mel4787 View PostTake your time. No rush. Apply as much as you can so if cm11 gets built you have everything you haveFreaktab Rom Developer
There are currently 1301 users online. 1 members and 1300 guests.
