Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
New ROM uploading currently... Who wants to test?
I'm currently uploading my modified version of the official update for the NX785QC8G...
Pre-rooted, init.d, adb root, etc...
Who wants to try it before I release it publicly?
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostYeah... something like that...
I'm partially done with it, just a few more changes needed to fix the mount points and such... and possibly add some custom mountpoints.
Then I need to decide if I want to try porting any additional Rockchip specific features from the stock SDK or not... I'd really like to add the ability to flash update.img formats to TWRP, but not sure how much work would be involved.
ShaunMTOriginally posted by mel4787 View PostI'll be the first to test it out
I'll b second
I'll PM you guys with the test link.
I'll PM you guys with the test link when it gets done uploading...
Installation is simple...
1. Unzip it to find the update.img file
Then you have 3 options:
Option 1. Put the update.img on your external SD card, boot into stock recovery, choose update rkimage from external storage, wait...
Option 2. Put the update.img on your external SD card, boot into android, choose yes when prompted to install update.img
Option 3. Flash from PV using one of the many rkflash tools (you'll have to look elsewhere for flash tools and instructions... check the forums here at Freaktab)
After install... I strongly advise doing a factory reset and recommend erasing SD card also.
Also, don't leave the update.img on your external SD card, because you'll be constantly prompted to install it over and over again...
Originally posted by mel4787 View PostFactory reset why?
Dirty flash if you like... but if you have any problems, a factory reset should be your first troubleshooting step following a ROM flash...
There are currently 4877 users online. 3 members and 4874 guests.
