Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
Originally posted by Perfectpitch View Post
Here is mine open all connections seem in place. Not sure where to check if its lose though. Or where to put plastic to keep it from becoming so
Originally posted by mel4787 View Postyou still having problems shaunmt with twrp?
It wasn't a problem with TWRP after all... I just wasn't preparing my update.zip files correctly for KitKat.
I'm back to scripting and testing the actual update process. It's still a multiple step update process, but I'm trying to automate it so the users can download a single zip, flash and be done.
ShaunMTFreaktab Rom Developer
Originally posted by mel4787 View PostHmm I'll test this first file of twrp.
Do you know how to use any of the rockchip PC flashing tools?
That is one of my personal requirements for testers this time around. I just don't have time to hold anyone's hand and help them unbrick a tablet if something goes horribly wrong. Anyone who knows how to use the PC flash tools can easily unbrick their own tablet.
Originally posted by mel4787 View Postits a natural thing with me. so yes ik how to use it. what do you want me to test with it. since this recovery is new to me i am partial to philz recovery but i will test anything out
Everything seems to work, so you'll be able to try out any and all features. I've even made it possible to back up and restore every partition on the device.
It might be hard to find a compatible update.zip to flash though... older update.zip files won't work with KitKat. They have to have new update-binary and updater-scripts in them.
Maybe I'll find time to package an update.img so you can flash TWRP from stock recovery and then an update.zip so you can flash back to stock recovery from TWRP.
Originally posted by mel4787 View Postok. think you can get omnirom up and running as well
I've compiled it, but I still have to figure out which drivers and libraries need to be pulled out of the stock ROM to make all of our hardware work. I'm guessing, it will take a lot of trial and error...
I haven't even attempted to install or boot it yet.
Once I do get it stable, it should be easier to switch the code base and compile a different ROM.
Originally posted by mel4787 View Postthere is a way to get the drivers and such pulled from the device
or the boot.img, depending on where different things are located...
Originally posted by mel4787 View Postlol. since its built what did you use to build it
There are currently 2397 users online. 0 members and 2397 guests.
